3.2 Engine/Trans Mounts
I just dropped my engine for a round of cleaning/sealing/etc.
I see that new Engine and transmission mounts are not too expensive. As my car is approaching thirty years old, I am thinking it may be time to renew all four mounts. Is this a waste of money, or bang for the buck? Thanks so much.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
porsher
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Agfours
Just changed all 4 of mine, and the ones that came out were in good shape. Put standard (cabriolet) replacements in and could definately tell a difference in the consistency of my 915 (less balking) and amount of engine / trans rotation when getting off / on the throttle.
Its very easy - just make sure to support each of the units (engine / trans) when you remove a bolt, and only do one at a time (in your case since you have the engine down, this may not be of issue, but for others reading...). You will have to support the engine to the point where the car almost comes off the ground to ensure it doesn't drop down too much when you remove the mount. Make sure you have a sleeve/bar to extend your breaker bar - those bolts are ON there. Cheap. Easy. Do it.
Paul Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..." |
1984 911 Targa - "Sabine"
Agree. I changed mine with last engine drop - easy day. Good luck
Skip 1984 (RoW) 911 3.2 Li Carrera - "Sabine" 2011 Cayenne S |
AutoBahned
I also agree. But, first, think about whether you would like a little more "connectedness" of the powertrain to the unit body (at the expense of some increase in NVH).
Here are your choices ranked by stiffness (tho I may blue/black Wevo reversed): 1. stock mounts 2. sport mounts, aka cab. mounts 3. Black Wevo 4. Blue Wevo even more combinations can be had if you mix the engine rear vs. trans front mounts as some people do... |
I did the engine mounts - change seemed transparent - I noticed nothing.
A few months later I did the trans mounts (G50 / 2-part polys from our host) - a little more noise, but shifting actually improved a tad. No regrets. Not sure if this helps w/ your 915.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
I changed my worn out ones with Wevo's and it gives a firmer set-up.
/Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Member 911 Anonymous
+1 go with the Cab Mounts aka Sport Mounts
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
