Went over a bump, engine died
As I'm sitting here waiting for a tow, I figured I'd ask you guys for your thoughts.
I was driving along, everything was fine. Went over a rise (not even a sharp bump) and the engine died. It cranks but doesn't turn over.
I don't hear the fuel pump when I turn the key (typically hear a whine). Moved the relays around (doesn't seem to be a fuel pump-specific relay) and jiggled and tightened the fuses. Nada.
Any thoughts on the problem or ways to diagnose?
Old 03-15-2012, 06:16 AM
T77911S's Avatar
you need to post the year.
check all the fuses. wiggle them around. i usually give them a few twists back and forth.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-15-2012, 06:40 AM
Sorry, first time on mobile. Thought my sig would post. 89 911 carrera. Twisted the fuses around as you said.
Old 03-15-2012, 06:48 AM
T77911S's Avatar
they are all good???
check for spark is the first thing, preferably at the spark plug. guess i could have posted that in my post too.
RACE CAR:: sold
Old 03-15-2012, 06:52 AM
also check in the rear engine compartment , unplug the the engine harness and plug it back in , its under the fuse cover , it's a big plug in harness on the side, I happened to me and a friend before and that worked, good luck
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 03-15-2012, 06:58 AM
RETIRED
Joe Bob's Avatar
As always...check the DME relay if it's clicking when turning the ignition to 'on'....
2012 ML350 3.0 Turbo Diesel
Old 03-15-2012, 07:01 AM
Chain fence eating turbo
First time I'm going to say this but it does sound like the DME/fuel pump relay under your seat may have died.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-15-2012, 07:03 AM
na2ub's Avatar
Check your fuel pump relay under the front hood. Its in the fuse box, and is a big round, usually red, relay. These rattle loose and will cause your car to die. After you re-seat it you can either tape it in, or bend the pins slightly outward / inward to keep it from rattling out again.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 03-15-2012, 07:48 AM
Happened to me this am. Car started, idle stabilized and then went hunting. Could not rev the motor. One of the electric plug ins, center left, into the FI system was a bit loose. Pushed it in and ran great. Good luck. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 03-15-2012, 08:11 AM
1970 911 T
died
Could also be the sensors on the flywheel that are loose.! or got out of specs
dosent`take much so the car will not run!
Old 03-15-2012, 09:26 AM
Appreciate all the replies. Turns out the fuel pump gave up after 23 years of faithful service.
As it turns out, mike from formula motorsports was out test driving a customers 996 and saw me on the side of the road. I'm at their shop now, having been fed and entertained while they diagnosed the issue, then ordered, received and installed the part. About to take off now.
Old 03-15-2012, 10:55 AM
Good to hear!
Old 03-15-2012, 01:41 PM
A breakdown does not get any better than that unless the car mysteriously starts and gets you home. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 03-15-2012, 05:27 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Wow, lucky you for a Porsche wrench to just happen by. that is awesome!
Still though, carry that extra DME.
'85 Carrera Targa
PCA/POC
Old 03-15-2012, 05:33 PM
