1980SCMan
Alan Lindquist's Avatar
Help Please - Engine Hesitates (Bogs) Under Load
1980 SC. At first I thought that my clutch was slipping. I did the 5th gear pull from 25 mph and there's no slipping. Clutch is a Sachs with less than 25,000 miles.
Perfect idle. Revs in neutral are clean and crisp. But when driving (in any gear) the engine seems to bog and hesitate and stumble under load.
It's been raining a lot. Could be a bad tank of gas. Could be bad timing. Could be clogged fuel filter. Could be poor spark. I have a "tired" fuel pressure regulator that causes rev surge in cold temps, and I haven't put the pressure gauge on to confirm pressures, but other than idle, the engine runs strong when when ambient temps are > 50 degrees.
Have an 8 month old rebuilt Bosch ignition box, 18,000 mile Bosch plugs, 120,000 mile+ ignition (shielded) wires. Cap and rotor look "ok" but not fresh.
Where's a good place to start?
This is a daily driver with 250,000 miles on the motor.
Old 03-19-2012, 05:48 PM
1980SCMan
Bump for any suggestions?
Old 03-20-2012, 06:40 AM
ROW '78 911 Targa
timmy2's Avatar
Wires, cap and rotor for a quick, less expensive start?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-20-2012, 06:54 AM
Home of the Whopper
Plus spark plugs
Ignition timing
Then check air/fuel ratio
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 03-20-2012, 07:02 AM
RETIRED
Joe Bob's Avatar
CIS? First check is fuel pressure. Then fuel flow......filters.......then vacuum leaks.
2012 ML350 3.0 Turbo Diesel
Old 03-20-2012, 07:14 AM
kodioneill's Avatar
Check Timing with a timing light to see if you're getting full advance.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-20-2012, 07:32 AM
1980SCMan
Well... congratulations. All of you were right. Which is kind of bad for me.
1. Lean running condition from vacuum leaks at injector seals. Seals now fixed.
2. Stuck fuel injector - cleaned and put injector cleaner in the tank.
3. Lean-run plugs "white frosted" needed to be replaced
4. One spark plug boot not making solid contact - replaced
5. Timing too far advanced
Now it's possible to see if the Lamda is doing it's job. Power to the unit and relay works. Need a test unit to compare.
Old 03-21-2012, 10:46 AM
