No reverse lights
hi,
took the car out yesterday, incredible weather !
noticed the reverse lights are not working.
other lights all work fine
I guess the first thing would be to change them ?
suggestions ?
thanks
Luc
1978 911 SC targa
Old 03-19-2012, 09:12 AM
If both reverse lights are out, it may be both bulbs - or the wire in the front of the transmission where the switch is may have come loose (more likely).
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 03-19-2012, 09:24 AM
SweetWaterSurprise's Avatar
Check your reverse light switch for sure.
Old 03-19-2012, 09:29 AM
Delusions of Adequacy
Uber-fanatic's Avatar
I have the same issue (have for a while now) - I know the bulbs are good...anyone have a picture of the wire/switch that's in front of the transmission? I'll be under my car most of the coming weekend and would love to make an easy fix if possible...
1974 911 3.0 (makes me )
2004 Toyota Sequoia
2000 Honda CBR XX1100 Blackbird
Old 03-19-2012, 09:37 AM
ArticSilver84's Avatar
reverse
Luc, vérifie la connection des 2 fils à la transmission, Ils sont peut être déconnectés !
Ou pire,,,,,,, la pin qui fait le contact à l`intérieur de la transmission est peut être cassée ou débarquée. Ca m`est arrivé l`an dernier.......!
Old 03-19-2012, 10:10 AM
Rex
Old 03-19-2012, 11:49 AM
DAMN!
Walter_Middie gets the gold star for today! Thanks Walter...I wish every inane question I pose was so quickly and clearly answered. Very much appreciated!
2004 Toyota Sequoia
Old 03-19-2012, 04:55 PM
And I tought it was simple...
Luc
1978 911 SC targa
Old 03-19-2012, 06:44 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Well it is kinda simple to replace, mine was leaking but functioning:
Disconnect Negative side battery
Raise the front end and safely secure with jack stands, chock behind wheels.
Get under her and remove the connectors carefully then the switch. CAUTION gear lube may leak out, be prepared, I did not raise my car high enough and lost quite a bit of gear lube, no worries, I was going to swap the gear lube in any case. If I drained the old gear lube first would have been less messier,
Install in reverse order.
That's it.
For those with older 915's watch for the pin, it may pop out.
Oh snap, I knew there was a cover for that switch
'85 Carrera Targa
PCA/POC
Old 03-19-2012, 06:55 PM
