911-106-033-05 Hub Extension for Alternator
Per Porsche Bulletin an upgrade alternator should be installed when
replacing a bad alternator on my 1983sc.
I can find the new alternator but can not find the hub extension
911-106-033-05
When I use the old hub extension i.e. fan hsng extension 911-106-033-01 and cut a notch in it for the new built in voltage regulator it still will not fit the back of the new alternator.
What is this hub extension do? Do I really need it?
WTB - 911-106-033-05 does anyone have this part?
Old 03-07-2012, 03:12 PM
The hub extension directs cool air to cylinders 1 and 2..you require it.
The 83 . should have had a Paris-Rhone alternator with built in VR.
Ordering the proper alternator, Verlo is the replacement name now should be a drop in fit unless you wound up with the Carrera 84 and later then nothing will fit.
Bruce
Old 03-07-2012, 06:33 PM
The bad alternator is a Marchal 71233002 70amp alternator with a HUCO 130216 external voltage regulator.
I ordered and received a Valeo W0133-1597770 75amp Alternator as an upgrade per Porsche Bulliten.
The problem is the 70amp Hub Extension does not fit the new 75amp alternator
even after cutting a notch in it as others here have advised. Now after cutting and
cutting the original hub extension looks like it was shot with a shotgun as
it has holes all over it. Is it usable like that?
When ordering the Valeo 75amp it said per bulletin I needed to purchase
a few items. One of the items needed was part: 911-106-033-05
Hub Extension now I see why. Sorry to say the upgrade hub extension is NLA.
Any thoughts as to what to do?
Old 03-07-2012, 07:22 PM
ROW '78 911 Targa
timmy2's Avatar
Auto atlanta says they have it. Give them a call?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-07-2012, 09:33 PM
Thanks,
I called Auto Atlanta and it is NLA. They checked the part number
911-106-033-05 and said it is listed as discontinued or so they said.
I guess I can't upgrade the alternator. I wonder how others
are doing it.
Thank you for your response!
Old 03-07-2012, 10:38 PM
ROW '78 911 Targa
timmy2's Avatar
Check this thread out, one of these guys may have what you need!
WTB Fan Housing / air diverter
Dennis
Old 03-08-2012, 12:07 AM
The Hub Extension in the link you provided looks like the 911-106-033-01.
Notice there is not a notch for the newer version alternator with an internal voltage regulator which is part number 911-106-033-05.
I have seen a picture of the needed hub extension 911-106-033-05 somewhere but can't find one.
Old 03-08-2012, 12:22 AM
Okay I figured out where I was at error.
Yes, the original Hub Extension will work on the new alternator.
Yes, you just notch the hub to fit the new internal voltage regulator.
What I was doing wrong was attempting to make the hub fit
flush to the alternator prior to installing it into the housing.
After installing the alternator into the housing it is clear that it
would not be flush if installed outside the housing. My bad!!!
Thank you for you input. It really helped motivate me to rethink the problem.
Old 03-08-2012, 04:10 AM
Did you happen to take pictures of the modification to your existing hub extension? I have to replace the alternator on my car soon, and it will require this same upgrade that you just did.
Thanks!
Old 03-08-2012, 06:18 AM
I have been taking work in progress pictures.
I will post them as soon as I complete the upgrade from a 70amp
alternator to a 75amp alternator per Porsche Bulletin which
of course requires notching the original hub extension.
Also, I will post a list of the parts required and used to complete the upgrade.
Old 03-08-2012, 10:53 PM
cgh911sc,
Did you ever finish the alternator replacement? Hopefully it worked out well.
Thanks!
Old 03-19-2012, 08:58 PM
Hi,
Sorry for the delay in posting pictures. Yes I'm still in the process of upgrading my alternator. While in the process of replacing the alternator I decided to paint the hub extension, fan housing, and fan.
I should be finished sometime this week and will post once completed.
Old 03-19-2012, 09:32 PM
