CT Mike's Avatar
Oiling K&N air filters
What are the engine symptoms if you over oil your K&N air filter?
Old 03-20-2012, 03:47 PM
Navin Johnson
TimT's Avatar
A little more info is needed...
What year car.... stock or modified engine?
'69 911 GT-5
'75 914 GT-3
and others
Old 03-20-2012, 03:54 PM
Banned
I doubt there would be any . . .
Old 03-20-2012, 04:44 PM
Oh Haha's Avatar
I agree.
Unless you really just went frikkin' nuts with oil on the filter it really shouldn't cause any major problems but maybe a bit of smoking once it gets into the intake andgets burned off.
His garage lists an 88 Carrera so we can probably believe that he has a cones style filter.
Pacific Blue
Wayne
Old 03-20-2012, 04:50 PM
CT Mike's Avatar
88 targa but with a stock air box. Thanks for the input. I wasn't sure if the air filter was the culprit as the car was idling a little rough and on take off seemed to veer toward stalling unless I gave it a little more throttle. The car is one tank full out of winter storage where I used stabil. Did the plugs and valves just before putting it away. Put in a can of seafoam today. Maybe that will help.
Old 03-20-2012, 07:40 PM
schumicat's Avatar
on a car with an air flow meter, excess filter oil can mess it up (which is one reason many people don't like k&n). but I don't think our old cars have one.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-20-2012, 07:42 PM
Diss Member
Quicksilver's Avatar
The contamination of the MAF by K&N filter oil is a wives tail used by dealers to get out of paying for failed sensors.
If anyone ever has a MAF sensor that the mechanic says has failed because of the oil from a K&N they should immediately call K&N. They will help you with the claim. They actually send out the sensors to have the "fouling oil" checked with a mass spectrometer. They have never seen a failed sensor from filter oil. The oil always turns out to be oil that has leaked out of the failed sensor itself.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-21-2012, 01:29 AM
tobluforu's Avatar
But it is true that if to much oil is applied to the filter, which can happen, that this oil can make it to the maf thus causing issues in regards to proper fueling.
Old 03-21-2012, 04:15 AM
rfloz's Avatar
On many Mustangs (sorry), the MAF has a very thin sensor wire that runs right across the air flow. It can be fouled (and give bad readings) if you really over oil a K&N. BTW, there is no other source for oil on this setup.
For those who do use a K&N, the aerosol filter oil is much easier to use than the drip kind and much harder to over oil with. Although I am sure some people could still do it.
Bob F.
1984 Carrera Factory Turbo-Look
Old 03-21-2012, 10:39 AM
one way to avoid this is to use the sticky spray on oil that dirt bikers use. Its a little tougher to clean, but it is much easier to oil the filter and not over oil it. on SC's, 3.2's over oiling would just bring oil into the intake, maybe a bit of smoke from combustion, but you;'d have to go nuts with the oil.
Old 03-21-2012, 12:26 PM
Banned but not out, yet..
RSBob's Avatar
I don't oil my K&N but then I don't live in a dusty, dirty area - too much rain for that. Besides the oil is changed every 3K, so not really worried about it. Just clean the K&N with every oil change.
And over oiling my K&N on my old 20V turbo Audi Quattro did foul the MAF which was rather pricey to replace. After replacement and going back to a stock oil filter the car ran fine.
Old 03-21-2012, 08:35 PM
Functionista
manbridge 74's Avatar
MAF fouling can be cleaned off with spray product. Sensor will not get destroyed from over oiling.
Want to know how good your filter/housing is? Simple test of smearing some wheel bearing grease on surface downstream from filter will either remain clean or catch dust getting by.
K&Ns need a pre-filter sock for dusty areas IMO. But test for yourself and see.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-21-2012, 09:13 PM
Dave & Tonya
darcher's Avatar
Is there any advantage to a K&N filter over a clean OEM filter? Any advantage to a cone filter vs a K&N that firts in the stock air box? I understand that the airbox and filter is not the choke pioint for a stock 3.2 engine, true? What is the most restrictive point then? The ads claim and increase in horsepower w/ a less restrictive filter.
Old 03-24-2012, 09:20 PM
Mitch Leland's Avatar
If the rough idling just started after you oiled your K&N filter I'm wondering if you pulled one of the rubber lines lose? I'm guessing that some where in all those hoses behind the filter box is a vacuum hose?
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 03-24-2012, 09:26 PM
AutoBahned
RWebb's Avatar
darcher - my understanding is that there is no advantage at all
some old threads if you want to search
or... consider that P AG is very big on "green" issues and has been for some decades - from at least the early '80s their policy was to not raise the hp on a motor unless they could achieve better fuel economy at the same time (according to Aichele, IIRC)
so, you might expect them to use an oiled, "repairable" filter instead of adding to landfill space (a huge issue in Germany) with a disposable paper filter - but they didn't
Old 03-25-2012, 12:07 PM
