cam oil line from host not correct
I ordered cam oil lines, the ones with the section of black hose in them, for my '84 3.2 carrera and the left side is 2" short and not bent the same. Is the correct one availble? Is there an update and I need more pieces? Also the cam oil line screws into a fitting close to the distributor, which screws into the block. I believe it's called a screw socket. What sealing ring do I need? I havn't checked the right side yet. Any help would be greatly appreciated. So thanks in advance.
Dean
SEE PHOTOS POST #4
Old 03-24-2012, 06:32 AM
steely's Avatar
yep, there have been a number of posts on this, the part number changed. Here is a post I saved that has some links. I'd send you my part number, but I have an 87 and it might be different.
Look at post # 19 (I put 18 at first) in this thread. I hope this helps.
EDIT - I am sure Pelican will work with you on this (exchange or whatever)
1984-left tensioner to cam line replacement
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-24-2012, 06:42 AM
schumicat's Avatar
I think the part you are describing is a ferrule and the host sells it. it doesn't screw in, it just gets compressed to seal.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-24-2012, 06:58 AM
Here are some pictures
Old 03-24-2012, 07:37 AM
steely's Avatar
I am correcting my post here. We're talking driver side line. (edit)
I still do recall having to do some research, since the original part numbers changed for some reason. I'll look to see if I kept that reference to a thread here. There was more than the normal level of confusion on it, and I think you need a diff part - a whole line as opposed to an extra part.
Can you give the Part number you ordered?
Dan
Venetian Blue
Old 03-24-2012, 08:50 AM
I tried doing a search, and found lots of confusion on this topic. So I started my own thread. Seems like very common replacement items. I'm sure there is a solution. Here is the part # I ordered 930-107-347-10-M20. Thanks for the help.
Old 03-24-2012, 09:08 AM
steely's Avatar
I may be screwed too.
I ordered the left side only after I had to do the right. I have not installed it.
I did have problems ordering it, and I haven't checked to see if I will have this same problem either now that I looked at your post.
I ordered 930-107-347-10-M20 as well - IIRC, the original part# changed, and this is what was recommended - I even had to wait for a back order.
I measured 13 linear inches end to end of the new part. Don't know my stock part length - (I'd have to remove the heater duct and distributor). Rats.
I will shut up now
A pic of my new part.
Dan
Venetian Blue
Old 03-24-2012, 09:26 AM
steely's Avatar
Dean - went thru my records -
I ordered OEM-93010734704, but they substituted 930-107-347-10-M20.
I asked Judy about it and was assured it was a suitable replacement - and I never looked back.
I can wait and work with them, although my order was made over a year ago (been working other things).
Let me know via PM if you need the email I got from her should you need to contact them sooner.
Dan
Venetian Blue
Old 03-24-2012, 09:42 AM
Which one is shorter?
Dean
SEE PHOTOS POST #4
Dean,
The driver side cam oil line is longer than the passenger side cam oil line. Have you test fitted the cam oil lines on to the engine? Keep us posted.
Tony
Old 03-24-2012, 04:16 PM
Pictured is the drivers side. It's about 2" short and not bent properly. The passenger side seems that it will work but not exact. I'm hoping oem parts are availble.
Dean
Old 03-24-2012, 06:28 PM
steely's Avatar
Dean
- here's a pic of my new hose laid next to the original still in place. Does yours look like this?
My new line does look shorter and may reach, but the profile will be lower and the cam oil line nipple is off to an inch or so to the right. I removed the heater duct - I may remove the dist cap, not the distributor.
To your original question, I have 2 new sealing rings, part nos 900-123-115-30-OEM - these are the same PN's I used when I did the right side.
If you could, let us know how you made out - and I will research to see if I can bend my cam line to fit. Threads here say it's possible, but I am not sure how much is reasonable.
Dan
Venetian Blue
Old 03-25-2012, 08:58 AM
steely's Avatar
better pic, white tube is a prop.
Dan
Venetian Blue
Old 03-25-2012, 09:05 AM
Mine looks just like it . It will work. I'll have to move the chain tensioner line over or buy a new line. I think the chain tensioner line might be updated with an anti- vibration bracket mounted to the chain housing cover. I removed the distributor to get on the line. I need to find the part number for the screw socket sealing ring also.
I'm getting a crash course on working on an air cooled Porsche. I absolutely love it. I've only worked on 60s,70's early 80's muscle cars.
I'm just cleaning up my car. The oil leaks seem only valve covers and oil lines. So I've done a valve adjustment, spark plugs, ect...I also found the intake runners loose so snugged them up.I'll remove all that stuff after I get this done. I've removed the muffler, engine tin, compressor brackets just to clean everything up. None the less I really like working on this car. Can't wait to drive it.
Old 03-25-2012, 09:43 AM
steely's Avatar
That's great news - this is the only car I have really worked on - the right side was the one that leaked on mine, and the replacement took care of it. I have done a lot of maintenance, and no oil drips on t he floor for one year now. I did no work this winter because I love driving it so much. Good luck and thanks.
About the vibe bracket - there was an update in 86 and rolled out Jan 87. I think mine already has it. In another thread, some cautioned about bending the line - eliminate stress or the line (hard Cam tensioner line) or it may snap. Curve ball is the hose PN change that you and I are going thru. I do not know the newer line PN or about the screw socket sealing rings. I posted the sealing ring PN above - the ones for the banjo fitting.
Dan
Venetian Blue
Old 03-25-2012, 11:01 AM
