Local Mad Scientist
need opinions, chain tensioner upgrade
Alright guys, I don't know who all has been following the resurrection of my 1982 911sc from a 16 year garage slumber.
I talked to my mechanic yesterday to get ready for sending the car to him for state inspection, ride height adjustment/alignment and some other checks. He just brought to my attention about the chain tensioner upgrade. Unfortunately I am at the end of my budget with everything. So here is my dilemma. Either A)let the car sit for a few more months (it's also summer and I would like to drive it) and get the upgrade or B) can I get away with the tensioner safety gaurds that I read about which is a 28 dollar a piece part from automation.com and use them this summer as a safety net/insurance plan (just in case) and upgrade to the tensioner kit this winter when I have more of a budget back. If I go with choice B, I would be getting new chain rails and all while I am in there.
1982 Porsche 911sc 2009 Jeep Grand Cherokee Laredo X CPA-PCA Member Since 2012 |
Andy (Andy911sc),
Go with “Plan B”. There are Factory ‘rebuild kits’ (a complete set of seals and pieces) for your tensioners. Install the Jerry Woods Ent. ‘safeties’. Install new chain ramps. ‘While you are there’, inspect the chains for ‘stretched length’ (you can replace them with ‘split-link’ chains if necessary. Inspect all the sprockets. You can (should?) replace the two cam oil lines. This is a good opportunity to check the cam timing. I’m in favor of rebuilding the earlier (‘Turbo’) tensioners compared to installing the more complicated (Murphy is in charge) ‘Carrera’ tensioners that are no more reliable. The only significant ‘improvement’ is the Carrera tensioner can continue to be driven while failing (it refills with engine oil). Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Local Mad Scientist
Grady,
Thanks, this helps my decision a lot. I tried to look on PP for the rebuild kits. Do you know where I could find them? I did notice that PP has the guards for less than automation.com. Also thanks for the recommendations on inspecting everything and replacing the chain rails. Andy
Google for 911-105-901-01 that's the kit part number. Equally important, check that you have the wide idler arms in there. If you have the spacers between the tensioner and the idler arm then find a set of wide arms.
andy |
Local Mad Scientist
Thanks, does anyone have information on rebuilding the tensioners.
Bandwidth AbUser
Jim R. |
There are also instructions in the 911 ('72-'83) Factory Workshop Manual, Vol. I, Section 1, p.p. 5.1-2/5 and 5.1-2/6. You will find the exploded diagram in PET (Porsche's on-line or CD parts manual) helpful. Best, Grady
andy |
Local Mad Scientist
Thanks guys. This is going to save me a boat load. Now I can do the work and I have a spare $200 in the budget yet. If I will need to use all that. Just guestimating.
One final question: Looking at it, I think I can manage doing this without dropping the engine. What do you guys think?
No need to drop the engine.
Remove the muffler. Support the engine and remove the two rear engine mount bolts. Carefully drop the rear of the engine a couple of inches – check the position of fuel lines, oil lines, breather hoses, wiring harness and everything else between the engine and chassis. Do NOT stress anything. Remove the rear (tin) pan. The oil-out pipe will be in the way but you can disconnect the support strap and maneuver past it. You may need to take the engine mount assembly off the engine to get to one of the chain ramp bolts (I don’t remember). The chain covers are now accessible. The important ‘hazard’ is having the engine suddenly drop while you are trying to ‘inch-it-down’. Use an adjustable jackstand or something to prevent this possibility from stressing the hoses, etc. You will find the muffler straps and flange bolts difficult to remove. Use penetrating oil and heat. It is best to use an oxy-acetylene torch to remove the muffler flange bolts. Drive to a shop with three new bolts and a gasket and have someone do this for you ($10 & 6-pack). Many remove the rear bumper for easier access but it can be done without removing the bumper. Does anyone have something to add? It has been decades for me. Best, Grady
I'm wondering why you feel compelled to go in right now and rebuild the tensioners?
Brian
'82 SC Targa '83 SC Cabriolet |
Local Mad Scientist
Thanks guys. I feel that I have been pointed in the right direction with this. I'm confident I can handle this now that I have advice from everyone with experience.
exhaust bolts are a pain, but I'll get it done. It's not my first rodeo. I just ordered the rebuild kits from the local dealer. Their price surprisingly match that of what I found online. This also gives me a chance to inspect the engine mounting hardware and replace my lower valve cover gaskets. If you guys are interested in seeing my resurrection and progress check it out. New to Pelican and new 911 owner
Local Mad Scientist
Car has been sitting in one spot since 1995. I am resurrecting it from this slumber. I just don't want any surprises and don't want to have my first drive in the car be a failure because I just ignored something. Yeah I was able to turn the engine over by hand, so I know nothing is seized up and the tensioners are doing there job, but I don't want them failing on me once I put them under load and stress at high rpm's.
I have two NOS rebuild kits with old tensioners and instructions from Porsche workshop manal. I installed the Carrera tensioners instead of rebuilding mine. I'll sell them for $25 each includes shipping. Let me know.
69 911 2.3Ez 85 928S |
you describe a partial engine drop. Does your recommended procedure mean that the transmission can stay attached as is? How about the shifter linkage etc?
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Local Mad Scientist
I wish you would have gotten ahold of me earlier. I already ordered the ones from the dealer today.
Local Mad Scientist
porwolf,
are you thinking about doing the same thing?
Yeah, thinking, looking at all options. I don't feel I have an urgent need now with my original 50,000 miles on the 79 SC and I cannot detect any lose chain noises. I was more seriously thinking about upgrading to Carrera tensioners a couple of years ago. But then the kits were offered for $350,-. Now it is 3 times that much! So, maybe, just as a precautionary fix I could install the collars. I will probably give it more time. And since I owned the car since it was new, and I never raced it or drove it extremely hard, I guess my original tensioners have some more life in them. And for the SCs, as I read here, chains jumping the sprockets is a rare occurrence. For the time being, I will carefully watch out for chain noises. I hope I am doing the right thing.
Local Mad Scientist
Does anyone have the gap spec for between the safety collars and tensioner body?
Local Mad Scientist
