Please help,
I got my 911 SC 3.6 conversion engine oil changed by none Porsche experience shop. They overfilled the oil by 3 quart! I did not notice it right away, I left the shop and the car was running normally (no smoke) but after a hard right turn, the car started to smoke like crazy and the engine started to run poorly. I did not push the engine hard. After a short drive home, I removed the excess oil and went for an 1/2 hour drive. At first it was still smoking a lot but after 15 min or so, smoke was reduced but did not disappear totally. Now the car smoke a little when the engine is running and still smoke a lot on startup. The engine is still running poorly (low power, shaking at idle). I think it's not running on 6 cylinders. Can an oil overfill generate serious engine damages?
Walter 79 Euro 3.6 911SC: Track machine 06 Magnum RT: Family and winter drifting machine 81 BMW R100RS Cafe Racer: Bicycle machine |
you are going to get a lot of \' go sue the pricks comments but the reality is your plugs are fouled . \if you have fixed the oil level you need to change the plugs and if you can get your maf off clean that up with some contact or brake cleaner ... then go burn it all off ... not a \huge deal ..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Lesson learned, I hope.
It's not a big deal. I would suggest taking your air cleaner off and cleaning out the box and clean up as much as you can. As theiceman posted, clean your MAF and all of the parts associated with it. I don't see a need to replace the sparkplugs. it should run ok once you get the oil cleaned out of her. It may smoke for a while but it will burn off.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
muck-raker
+2...not a big deal if you clean everything up and drive it briskly for a short while. I'm still pretty new to Porsches, but not new to air-cooled motors. Although I've not ever heard of it on this site, my experience has been that overfilling most air-cooled motors (particularly VW) usually results in a leaking main seal. I hope this is not the case for you.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Team California
Overfilling 911 engines frequently results in them being towed into a shop that does specialise in Porsches covered with that foam that comes out of fire extinguishers. They start puking oil out the breather as soon as the engine warms-up, it hits the hot exhaust and the rest is history. You're very lucky that this did not happen.
Let this be a cautionary tale against letting someone w/ "none Porsche experience" touch your car. In most all cases, you are better off doing it yourself w/ advice from a BBS like this. (Or at least reading the owners manual first). These air-cooled cars are not that exotic, just exotic enough to completely destroy by something as simple as an oil change. Glad it worked out as it did.
Denis |
If the engine does not see high rpms while overfilled then no real issues should happen.
If you spin the engine the seals will blow out, ring damage and hydrolock can occur. Good posts on what to do so far.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Thanks guys, that's a relief.
![]() It's the last time this car is touch by an none Porsche mechanic.
DO NOT use Brake Cleaner to clean your MAF. Use MAF cleaner, which is readily available at NAPA.
Also, you may want to add a catch can inline in your breather circuit. Doug
1971 RSR - interpretation |
this post should be mandatory read for all newbies ,
this should start out with once upon a time at an IFFy lube far far away a man who didn't know better took his Porsche to a place run by those who don't know better they did what they thought and check the stick twice filled it to the top and said that looks quite nice it smoked and it shook and it scared him back home into the garage were they (the car and he) could be alone he checked it all out and then made his post hoping all the while that his engines not toast the gurus they read and gave there advise told him to drain down and clean it quite nice we hope it works out and that all is swell and they man a the IFFY lube goes straight to hell so don't touch a Porsche if think or don't know but please ask first a PELICAN they will probably know ......... moral of the story is _____ work on it yourself or pay some one who knows or ask Wayne's Pelicanite's they probably know |
Senior Advisor
I like it! very phuny
08 Cayenne Turbo |
muck-raker
80_911SC,
I always knew you had a hidden talent.
bump , just because i like my comment .... #9
I'm bumping too!!!!
Love it!
'65 Porsche 912 (painted dash) #451232 '65 Porsche 912 (painted dash) #451425 - 13 days younger '78 Porsche 911SC - Resto garage queen |
One time I didn't have time to do my own change just before storage so I took it to a very good local general mechanic just around the corner. I left him with the Bentley manual and a little extra oil and asked him if he knew the drill on these cars. Yeah, yeah. When I picked it up, all the oil was used...that's strange, I guessed that be had managed to remove more of the oil from the front cooler and lines. When I was about to drive away he said had to add a quart from the shop because I hadn't left enough.... the penny dropped. Sure enough, there was at least two quarts over the center line when warm at idle....lesson learned, ONLY experienced "Porsche people" touch my car....other than myself.
Never.....ever....(when it's important...as I found out even in my professional life)....say to someone.... "Do you understand?...and accept only a "yes" answer WITHOUT EXPLANATION.
Ask the person to whom to you ask a question.....to answer you back fully with details ( aka "paraphrasing") Yeah...sometimes you come off looking like a jerk trying to talk to a kindergartener....but if it's important, you do this.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
My motto is: Always make sure the person doing work on my car is smarter than myself. Why let anyone dumber than myself mess with the car?
The answer to the OP's question is YES,......and this SERIOUS damage would be known right away.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
My question is: surely you had them correct this issue before leaving-driving off (after the penney dropped)? Right? Doyle
76 911S Targa
One other thing. Look your engine over carefully. The oil can and will run out of the airbox, over the top of the engine and down both sides and then onto the exhaust. My point? You may need to thoroughly clean off the engine exterior with a steam cleaner, degreaser or power washer. All caveats about keeping the ignition dry apply here.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
