Functionista
manbridge 74's Avatar
Spring, when a young mans fancy turns to rust...
..... prevention that is.
Just looked up into my rear wheel wells and right at the highest point were some cracks in the undercoating. A screw driver twisted into cracks removed a section about 1 inch by 10 inches long. Only suface rust was visible underneath. A little wire brushing, rust converter, zinc primer, paint and some more Wurth undercoating are all that is needed.
Check your early models and early mid years before it becomes a serious issue!
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-28-2012, 04:23 PM
KNS KNS is offline
Ouch... What year?
Kurt
Old 03-28-2012, 07:35 PM
'74?
2007 Cayman
1986 Carrera coupe (sold)
1979 911 SC targa (sold)
Old 03-28-2012, 07:40 PM
Functionista
Yes, a 74.
This car has a thick undercoating which might be too thick as it lifted off in chunks at the peak of the wheel arch. I removed loose stuff back to the impossible to remove stuff.
It also was Ziebarted in 1974, still have the receipt. And it appears an Arizona/Colorado car almost its entire life. Point being, all areas should be inspected yearly for hidden rust. Even if it looks good, you gotta poke around a bit.
Any suggestions for treating such areas?
Jeff
74 911, #3
Old 03-28-2012, 10:18 PM
JmuRiz's Avatar
Ziebart, eeek, I'm interested to hear how the experts suggest tackling this one too.
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 03-29-2012, 10:47 AM
Taking it apart is easy
Jerome74911S's Avatar
OK, so I crawled under my '74 to do something else and sure enough, up at the highest point in the rear wheel well there were some gaps in the undercoat. I poked around with a screwdriver and cracked off some sizeable chunks, same as you did.
The thing is that the gummy stuff up in there was not routine undercoat, but rather some PO's idea of an appropriate sealant. It's almost like caulking compound, but it's hard to tell.
In any case, I want to do a good repair but I'm not sure what to use. Just appropriate paint over the metal followed with Wurth, or comparable spray undercoat seems too easy.
Is there some thick glop that can be squirted up there (it's hard to reach) that will really seal that seam permanently?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 04-01-2012, 06:35 PM
E Sully's Avatar
Jerome, that gummy stuff was Porsches idea. That is what they seal the bottom of the rear window frames with.
Ed
1973.5 T
Old 04-02-2012, 03:16 PM
No doubt that is so.
In this case I took a closer look and discovered that there was a layer of closed-cell foam, which was plastered over with undercoating of some sort.
The foam is breaking down, therefore, the cracking. I'll dig it out and reseal somehow.
Jerome
Old 04-02-2012, 03:28 PM
