Senior Member
Adjusting the idle on a 3.6
Tried searching and no luck.
Anyone know how to adjust the idle on a 3.6 964 engine? Its at times going up to 1200 at idle and would like to bring it down a bit. Thx, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
either you have a minor manifold leak or need a new idle control switch (unit),don't believe there's a manual adjustment
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
i had the throttle wire routed in a way that there was too much friction in the wire which prevented the throttle to close completely.
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
Senior Member
Thanks and will check all of the above!
What should the engine idle at normally? Am guessing 900 rpm's or so? Joe
mine is 95 993 3.6 with custom chip. it idles a little high at 900 rpm or so.
don't know where it should be but i trust the guy who did the chip.
Senior Member
Thanks for the info everyone!
Joe A
