cam timing
Its time to time the cams on my 84 Carrera. The modifications Ive done are a 3.4 Mahle cyl set,twin plug conversion and custom chip. Should I set the cam timing to factory specs?
you should ask this question on the engine rebuild forum. You will probably get more answers.
I would rather be driving
If you have the stock cams then time them at the factory spec. If you swapped cam grinds then you should use the spec that came with the new cams.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Thanks! My cams are factory stock so I will time them to factory specs!
all that work and stock cams? why?
