Help
I have been lurking here for over a year. I have a problem and I am unsure where to start. I purchased an 82 911SC last spring after making the mistake of driving it. I was instantly hooked. The car had 140,000 miles on it and needed only minor cosmetic help. Over the summer I put over 5000 miles on it and it ran wonderfully. Changed the oil, fuel filter, fan belt. Car had new plugs and points, dist. cap when I bought it. When I got it out of storage this spring it started right up, idled well. I put stable in it before storage. On acceleration in stumbles like it is not getting enough fuel. At any constant steady speed it runs great. Should I look at the FI or electrical first. Just seems odd that it ran well before storage. I have never stored a car over the winter before. Thanks, Tom
Old 03-29-2012, 06:51 PM
Hi
Targa Me's Avatar
I would guess condensation. Stable or not.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 03-29-2012, 07:39 PM
ROW '78 911 Targa
timmy2's Avatar
Drain the old gas and put fresh fuel in it with some techron additive to clean things up.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-29-2012, 07:43 PM
76 911S Targa
Yes. You have fuel that has sat too long in the tank. Use lots of fuel conditioner/injector cleaner and run out the old fuel or drain the tank and refill with fresh. Still use injector cleaner to clean the fuel system.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 03-29-2012, 10:39 PM
Thank You, I did not think the fuel would go bad that fast. The car is in for some paint touch up. I will try your suggestions as soon as I get the car back. Thanks, Tom
Old 03-30-2012, 04:13 AM
Canyon Runner
70SC's Avatar
Ethanol is Hygroscopic : attracts H2O
Old 03-30-2012, 08:07 AM
ivangene's Avatar
something is wrong with Windows again...gotta re-boot
these pictures are not showing up....and he's owned it a LONG time SOOO it must be my computer
Ed M
86' Coupe
Old 03-30-2012, 08:12 AM
