Car Won"t Start Need Advise Please.
Car turns, but won't start. Checked the most logical place, the fuel pump fuse, no problem there, I don't hear any noise coming from the fuel pump when I turn ignition on. I've already heard that it might be either the fuel pump, something about a relay under the drivers seat or, the DME module. The question is what is the best way of troubleshooting this problem (using the cheapest option first method). Any help will be greatly appreciated!!!!!!!!
Gil |
Member 911 Anonymous
You wrote DME, so swap the DME relay under the seat. all 3.2's should carry a spare.
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=911-618-154-01-M252&catalog_description=DME%20Relay%20%28location%20un der%20driver%20seat%29%2C%20911%20%281984-89%29
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 03-30-2012 at 11:09 PM.. |
Thanks Draco! That did it.
muck-raker
another satisfied Draco A50G customer.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
