Smile The engine is back in!
Today was the day the engine went back in but I still have a few more things to hookup. I'm about 2 hours away from firing it up with the exception of the distributor rotor. When the engine was out I tried to remove the rotor and it wouldn't budge. So I gave it a little more force and removed it in two pieces. I called around and couldn't locate one locally. You guys in California are really lucky being close to the supply houses. So I'm a week away from starting it up due to a broken rotor.
The reason I took the engine out was to replace all the lower dilivar head studs with steel ones. I opted not to do a top end rebuild based on the mileage on the car and after inspecting everything. I also did the chain tensioner upgrade too.
Thanks for all the advice and help along the way. It's a great feeling to know I can always get help from this board.
John
Old 04-27-2002, 04:56 PM
one of gods prototypes
bell's Avatar
just in time for spring
i like your polished fan, i'm thinking of doing the same with mine.
lets see pic of it spinning when you get it running
Brought to you by Carl's Jr.
Old 04-28-2002, 07:01 AM
