Pitted caliper piston- can i use it?
![]() I am rebuilding my front calipers and ran across this pitting on one of the pistons. Will I have a problem using this? Thanks! |
I would get a new one. The pitting can make it leak and/or damage the seal.
Kay
- 2014 Porsche Cayman - Guards Red/Black - 1986 Porsche 911 Carrera 3.2 - Silver/Burgundy - 1973 Porsche 911 2.7S - Aubergine/Black - 2200 lbs ! - 1980 Porsche 931 - Malaga Red/Black (sold) - 2015 VW Golf 1.8 TSI |
Northern Motorhead
That is beyond pitting ... much safer to get a new one !
Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Smoove1010
I agree that the best answer is to get a new one.
This corroded area was probably outside of the inner seal (the square-cut O-ring) in the caliper cylinder, and was therefore exposed to the elements, probably due to a failed dust boot. While it's possible that you could polish this area down, unless you could get it perfectly smooth without altering the dimensions of the piston, it may damage that O-ring, or allow fluid to leak if depressed all the way into the cylinder, such as when new pads are being inserted. There's no real up-side to re-using this, and you might think about replacing the whole caliper. |
the only pistons I've seen available are for earlier years? I have a '79. recommendations on where I can find some?
They are available from Eric Shea (pmbperformance.com)
Noah 79 SC minerva blue metallic Eureka CA / Boulder CO Physics is like sex, yes there are some practical applications, but that's not why we do it. |
+1 Eric does AMAZING WORK on brakes.
Also... when it comes to brakes, no matter what I will not skimp. When in question about the very thing that keeps your life safe every time you press that pedal, it's best to make sure it's rebuilt properly or new.
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS |
Thanks for all the advise everyone. Those were my thoughts but just wanted to make sure before I shelled out another $70+ per caliper for new pistons. I will probably eventually upgrade to big brakes and didn't want to spend unnecessary money getting these up to par for the time being.
yes, just use thinner pads |
That is not pitted... it is dead.
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
I would measure how deep the seal is in the bore and see if that area will touch the seal. If not then it would be ok to use (especially for a short time).
-Andy
72 Carrera RS replica, Spec 911 racer |
Ask yourself this question....when driving down the road...and a big truck carrying gasoline pulls out in front of you and you have to make an emergency stop....will you make it with that piston?
Or...for the sake of a few dollars...? Bob
Bob Hutson |
Everyone makes very valid points. Thanks guys. With that being said.. new pistons it is! That is as long as my inspection of the calipers don't show any pitting as well..
- Peter '79 911 SC Widebody conversion w/ '80 3.1 engine '07 BMW 335i Conv '96 Ford Explorer Sport |
Author of "101 Projects"
I would not use that personally on my car.
Wayne |
However, if it were mine, i'd replace it
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) Last edited by Nine9six; 03-31-2012 at 01:08 PM.. |
If the seal isn't touching it, which I doubt, it's just as good as a new.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
OUT, it goes. Sooner, the better.
Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Using that is a good way to meet your local ambulance crew.
