Did Ruf ever make a fiberglass valance?
Did Ruf make a fiberglass valance or was all its products polyurethane?
1987 930, (Imagine Auto) 3.4L, dual plugged, Electomotive, k27HFS, Tial WG, SC Cams, Kokeln IC, GHL headers, HKS EVC5 boost controller, Bilstein coil overs, Big Reds on Front
Old 11-05-2011, 09:25 AM
Only the imitations were, RUF was poly/flexable.
Bruce
Old 11-05-2011, 10:59 AM
Bill Verburg's Avatar
The valances were p/u, the full bumper covers were f/g
valance, w/ integral chin
bumper cover, w/ separate rubber chin
Bill Verburg
Old 11-05-2011, 11:59 AM
lin7310948's Avatar
i have ruf front and rear bumper covers with integral spoilers such as the silver car above. i have the front grill panel but would like to use the same material for the fog light openings. does any one know what material that Ruf used for the grill and light openings?
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 11-05-2011, 01:07 PM
The silver car is mine, I used old stock engine lid grills for the Ruf grill material
Bill Verburg
Old 11-05-2011, 04:19 PM
lin7310948's Avatar
bill, do you remember which grill you used. i think that i have one of the plastic on
es from the mid to late seventies..not sure! thanks
update, i just checked and i do have one of the plastic grills and it is the same pattern as the one i am currently using in the Ruf bumper cover. thanks for the idea.
Old 11-05-2011, 06:02 PM
The Ruf lightweight front air dam is made of fiberglass from Ruf as is the rear valence.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 11-05-2011, 06:28 PM
I don't know where you get your info, but it is wrong
the full covers, both front and rear are f/g, the front valance is p/u
the valance is the part that is beneath the stock bumper, the covers totally replace the front or rear bumper
Bill Verburg
Old 11-05-2011, 07:52 PM
Hey Bill, I will bet you the silver car above that the lightweight parts were fiberglass. I own a Rug BTR the silver cum noted modified tuner car so no Ruf mechanical parts left however, I have sold more Ruf parts than you have seen in all likenesses. The Ruf lightweight under bumper valence that is devoid of fog lamp openings is fiberglass as is the slotted rear valence. You can call Ruf to verify as that is the source of my info further I bought and resold all of the parts Ruf NA that is the Canadian representative before Ruf came back to t
he U.S. through the Dallas group.
Lincoln Phillip
Old 11-06-2011, 07:39 AM
No argument there, that is a bumper cover w/ a matching rear bumper cover both are f/g, the front bumper cover has a separate rubber chin that is fastened to the f/g. The f/g parts on that car are aftermarket but the original Ruf versions were f/g, the chin is oem Ruf purchased from my neighbor in Fla. who was a Ruf distributor back in the day.
Apparently you do not read though. I do not know about the 'parts devoid of fog light opening' as I have never seen one from Ruf, but the parts I pictured and described are oem Ruf and are p/u
from post #3 above
the Ruf valances were/ are p/u, they incorporate the chin as part of the bumper instead of as a separate part as on the bumper covers and have an internal plastic structure that supports the cooler and grill and oem fog lights
again the bumper covers replace the bumpers and valances, the valance hangs under the front bumper and only replaces the stock steel valance and rubber chin
here are some more pics of the Ruf p/u valance and oil cooler kit
the whole p/u shebang
the inner oil coler mount
the oil cooler
Bill Verburg
Old 11-06-2011, 08:30 AM
Not trying to sound like an ass, because you a valued member of this board not that you need me to tell you that but you should be more careful when you tell people that they are wrong out of hand.
Lincoln Phillip
Old 11-06-2011, 08:39 AM
I do not have the benefits of photos at this time maybe your neighbor was James Aaronian, but let me state unequivocally that the BTR (wide body) under bumper came in Polyurethane for the standard and fiberglass for the lightweight from Ruf, also available in narrow body. These were made for cars up to '89 do do some research. Further, it is a bit puerile to sling insults so keep it civil.
Lincoln Phillip
Old 11-06-2011, 09:33 AM
m110's Avatar
I think there may be some misunderstanding between what is being called what, but my experience is precisely what Mr. Verburg describes. The CTR factory Ruf bumper cover that I have seen is f/g. The CTR style underbumper valence on my old car was p/u and in fact there was an ad in the old Automotion catalog of two guys twisting it like a pretzel to show it won't crack. I do not know about the BTR parts.
It appears the OP question is still up in the air:
Did Ruf make a fiberglass valance (CTR was p/u, don't know about other products) or was all its products polyurethane?(some were fiberglass, like the CTR bumper cover)
1988 Carrera Coupe
Old 11-06-2011, 10:19 AM
To be clear, the BTR came widely in PU it is what I have on my car, however, the fiberglass under bumper was available from Ruf. The CTR was available in PU, with the lightweight being fiberglass on both cars BTR and CTR.
Lincoln Phillip
Old 11-06-2011, 10:33 AM
lin7310948's Avatar
well i do not know which is correct and i have had both on my 930. i just want to thank Bill for the idea for the fog light openings. i just finished installing the same rear deck grill opening material in the fog light openings. it just looks so much better to me.. thanks again to Bill!
Old 11-06-2011, 10:34 AM
My car with the PU RIM spoiler, the lightweight version had no fog lights and was designed to function as a splitter as well.
Lincoln Phillip
Old 11-06-2011, 10:45 AM
You now seem to be agreeing w/ me. There was nothing uncivil in my post, if you are insulted then that is an issue on your end as you posted inaccurate or at the very least confusing information.
I merely stated the facts, which you now seem to agree w/
your post
is confusing at best and appears to contradict the facts that I posted
the valance used on the CTR as pictured in my posts was p/u, there may have been f/g versions from Ruf, there certainly are imitations, I made no assertions about that or about the w/b version.
My other statemant was that the full bumper covers, both front and rear, were f/g
I further stated that the p/u valance incorporated the chin as part of the valance and that the f/g full bumper cover had a separate add on rubber chin from Ruf, which is what is what I used on my car and was pictured.
Bill Verburg
Old 11-06-2011, 11:58 AM
petercory
I have the Ruf CTR 930 front & rear full bumper covers on my car; both have Ruf Serial number tags molded in and both are fibergass. The front also has the Ruf rubber lower lip.
Old 11-06-2011, 05:43 PM
FWIW, I had a Ruf front valence (not including the bumper area) on a 930 and it was fiberglass.
JR
Old 11-06-2011, 06:12 PM
Sorry it took so long to get back to this.
After several emails back and forth with RUF AG, it turns out that RUF did make some valances in fg. I could not get any more info from them. I tried to get production numbers, how sold (cars they modified v. selling retail). They changed computer systems at some point and any information regarding fg valances was lost. They must not be very common; the US distributor didn't even know that fg valances were made.
I was quite disappointed after I purchased since I thought all RUF valances were PU.
Old 04-02-2012, 11:31 AM
