Je Ne Sais Quoi = Targa
Sun visor problem, (What did you think I meant
) I know, kind of a Mickey Mouse problem, and will probably have a solution that will have slapping my forehead and saying "I should have known that".Recently added a 74 Targa to the garage, but it had no sun visors, OK, sourced a pair from a Pelican-oid parting out his '87 I believe was the year Targa, but they will not stay "up", the visors on my SC have a screw to adjust tension near the hole where the rod goes in, (Might need to rate this thread "X") these newer visors do not have these screws, solution?
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018, '81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust, Had a '71 911S Targa in the 80's, miss it, Had a '61 Roadster in the 70's, miss it also, Last edited by Mikey83835; 04-06-2012 at 11:39 AM.. |
i have the same issue. i think mine are aftermarket and have no screw. passenger side is good and drivers side droops. ive tried to make a makeshift bushing, to make it more stiff, but to no avail.
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
Banned
If you have problems keeping something else "up" then I suggest you buy a 930! Like an "older" gentleman stated in a thread a while back, the boost is better than the blue pill!
Member 911 Anonymous
That is strange? mine has the tension screw and it should be identical to the 87 targa.
Can you post a pic of the screwless visor for the supposed 87?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Viagra.
Seriously, you probably have the aftermarket ones with no adjustment screws. They're probably just a friction fit. You could wedge something in the hole shaft and try to stiffen the rotation or look into seeing if different hinge pins would fix the problem.
2007 Cayman 1986 Carrera coupe (sold) 1979 911 SC targa (sold) |
Is the visor rotating on the pin or is the pin rotating in the mount ? If it is the pin rotating in the mount maybe you can remove the visor and slide a piece of shrink tubing over the pin. Then reinstall.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Pic attached, they have little sliding doors covering the mirrors, cute, but I would rather have the adjusting screws ![]()
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018, '81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust, Had a '71 911S Targa in the 80's, miss it, Had a '61 Roadster in the 70's, miss it also, |
