I can't find my "911 Handbook". Does he give any ideas for a cooler set up?
Bruce |
Check out this thread - this is the setup I'll probably go with until I tear my trans apart:
trans coolers I'm going to replace my driver's side Mocal cooler with a center mounted cooler (suggestions?) and might use the old Mocal cooler for trans fluid.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Administrator
And put a switch on it. You do not need a cooler for street driving -- pretty much ever. I put a temp gauge on my tranny, and I've never seen temps above 180 anywhere except the track.
See this thread for info on temperature sensitive stickers you can use to see if you even need a cooler.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Myself, I'm going to use one of those relays with a temp sensor like I did on my oil cooler. I'm trying desperately to remember the name, but they're available @ PepBoys and the like in the RV accessories aisle.
Platinum Member
How does the cooler affect level of trans fluid? Do you just add enough to displace the fluid that is in the pump & lines? Or is less fluid needed because is is being pumped onto the gears instead of splashed?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
My assumption is that you'd have to add fluid to make up for the volume in the lines...
Thom,
Where can you get a cooler like that? Is it available as a kit or is it a DIY job? Looks cool.... Rick
Rick Katigbak Gretchen - 1972 3.6 ST-Replica No Name - 1966 911 - 2.7S powered |
I'm trying to come up with a way to spray that return at the ring/pinion and the gears. Any ideas?
Bruce |
Navin Johnson
Hayden would be the name the tranny coolers etc available at pep boys and other parts places
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Bill,
Thanks for the link. Do you know of any other tranny cooler setups available? I'm planning on adding a setup later this year but don't feel like putting the whole kit together and messing up a critical step. Rick
Rick, here's a pic(previously posted) of another setup done localy; the only thing missing is the actual cooler, which was removed from the circuit to facilitate quick swaps, the owner was having heaps of trouble with a rebuilt engine overheating, note the quick connect on the starter +
