I'm currently in the process of replacing drop link and sway bar (16mm) bushings in the front end of my '67.
How in the world do you get the sway bar bushings around the sway bar? Does it require cutting? The old rubber bushings were cut, but the one's I'm installing are polyeurethane (sp?) I need some quick help. Thanks
-TJM Carguy http://www.angelfire.com/mi2/tylermerkel |
Mine were split. Not sure of any other way to put those on without them being cut.hmmm..
72 911 Although it is done at the moment, it will never be finished. |
abit off center
boil them in water and they slip right on
Craig |
Alright, thanks guys.
Ended up cutting them on one side with a band saw, boiling, and folding them back and slipping them onto the bar. Thanks for the help!
