Jonathon
Torque Wrench
What kind of torque wrench is needed for basic maintenance on a 911. Harbor Freight has them for around $20.00, is that adequate? Also, what is the most commonly used size? Do I need to get a 1/4", 3/8", and 1/2" Thanks, Jon
Old 04-05-2012, 02:57 PM
rnln's Avatar
I think the first one would be the bigest one, 1/2", to torque your wheel lugs/nuts. Then the next one would be the 1/4", smallest you can get, for your valves cover nuts; which I don't have yet. I wish I can get something smaller than the one at HF. I also have some in between, which I rarely use.
Fat butt 911, 1987
Old 04-05-2012, 03:03 PM
redstrosekNic's Avatar
+1 on getting a 1/4in and a 1/2in. I have a 1/4 and 3/8in from HF. They work fine. I only use the 3/8in for torquing my oil drain plug, headstuds, and fan nut. My 1/2in drive is my dad's, which is some other brand. The 1/4in from HF is big for a 1/4in, but in/lb measurments are handy for things like the alternator strap and oil level sending unit. With some good small 1/4in drive torque wrenches costing above $100, the HF is a good compromise for most general stuff.
Dustin
Old 04-05-2012, 03:16 PM
Driver
Noah930's Avatar
Like rnln says, I also have 2: 1/2 in for the heavier stuff like wheel lugnuts, and a 3/8 in for most other things. I have Craftsman, myself. I've had them for about 10 years. There are better (more expensive) ones. There are cheaper (?less reliable/durable?) ones. The inexpensive ones often can't be rebuilt/repaired. Course, they're cheap so you just throw them out and buy another.
1990 Black 964 C2 Targa
Old 04-05-2012, 03:34 PM
AutoBahned
RWebb's Avatar
a torque wrench is not just a wrench; it is a precision instrument
I would never use a cheapo Harbor Freight one on my car - esp. on the wheels which could easily kill you if too loose
but there is no need to get a 1/4" one for the valve covers - just make them snug - search up the thread active in the last 2 weeks on this; I think Peter Z. posted, not sure
search up the numerous threads on torque wrenches for much much more info
Bottom Line:
get a good 1/2" one for the lug nuts; get 3/8 for engine or trans. rebuilds, and test them periodically for accuracy
Craftsman used to be fine; no idea nowadays
Old 04-05-2012, 03:49 PM
83 911 Production Cab #10
JJ 911SC's Avatar
I would never use a cheapo Harbor Freight one on my car - esp. on the wheels which could easily kill you if too loose...
+1
And remember the golden rule of tools acquisition, buy cheap buy twice...
Who Will Live... Will See
Old 04-05-2012, 03:56 PM
rnln's Avatar
talking about perfect torque, it is recommended to check/calibrate every month or so. I use to write documents for a limo manufacture years ago. They have all good/expensive torque wrenches and they can't skip this rule.
I went through several torque wrench and still get the HF because I figure for this price range, if it go bad, just get another one. Later, I realized that they went bad because it was my fault, didn't release them after each use. The last set I have (cheapo HF) lasted me years. Periodically, I checked them with a friend of mine. Can't remember what his was, but not HF.
Fat butt 911, 1987
Old 04-05-2012, 04:25 PM
Grady Clay's Avatar
Here are 1/4", 3/8", 1/2" and 3/4".
Originally Posted by Grady Clay View Post
There is a size for every job.
The critical one for the small torque wrench is rocker arm shafts.
Note the calibration decals.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-05-2012, 04:43 PM
What brand wrenches are they?
Dean
Old 04-05-2012, 05:22 PM
Nine9six's Avatar
+1 on Grady's post.
Multiple torque wrenches are needed depending on the application and torque requirement. Torque wrenches are most accurrate at +/- 60% of the respective wrench mean value. I.e, if you have a troque wrench rated for 25-100 ft lbs; it is most accurate +/- 60% of the midpoint (62.5 ft lbs)
Personally speaking, I would not use a HF torque wrench for any critical engine assy.
My experience and training are in aircraft / aerospace applications. Earthbound applications can and should be less stringent.
Some of the better torque wrenches are Snapon, Matco, Proto...Before I tossed away money on a HF torque wrench, I'd look for a good quality used wrench on craigslist or fleabay, and have them calibrated/certified at a local calibration shop.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-05-2012, 05:39 PM
I buy things like, gloves (for example) at HF. For precision tools I might buy new or used if it looks like it's a legit buy on eBay. I realize it's tough to know when buying used online. That said...I have a Mac that goes up to 150 lbs that I bought for $200 used and it looks like new. It is a beautiful tool that feels much different than a lesser quality tool. If funds are limited and you have to save bigger spending for the car, that's understandable. Been there and done that too.
Old 04-05-2012, 06:37 PM
HarryD's Avatar
Interesting thread: Is a Harbor Freight Torque Wrench Really Bad?
Personally, I own both a 1/2" HF and Craftman clicker type plus a 1/2" Craftsman beam type unit. Periodically, I check them against each other. So far they agree well enough to make me happy.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-05-2012, 07:05 PM
Send a message via AIM to mercury26 Send a message via MSN to mercury26 Send a message via Yahoo to mercury26
I recommend torque wrenches from CDI Torque (CDI Torque Products, America's Largest Manufacturer of Torque Equipment). The company is owned by Snap On and they make a quality product at a very reasonable price. You can purchase them from Amazon at a very good price. I have a selection of CDI Torque and Hazet (love me some German tools) torque wrenches. You won't be disappointed. As the other poster mentioned, torque wrenches are a precision instrument and as such you should invest accordingly.
Regards,
Chuck
Old 04-05-2012, 07:36 PM
Alps Adventurer
Traveller's Avatar
a torque wrench is not just a wrench; it is a precision instrument.
Bingo! Its unfortunate few see it that way.
I'd suggest he gets a 20 to 100 lbf.ft. 3/8 ich drive unit made by Precision Instruments who I believe make them for Snap-On. Its a flex head ratchet click type.
After that one, a 1/4" drive unit that takes care of all torques below that one.
Personally, I own three that cover from 3.5 to 250 lbf.ft....they're also calibrated.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 04-05-2012, 08:28 PM
Alps Adventurer
Traveller's Avatar
How do you know if it has gone bad?
All the best,
Alex
Old 04-05-2012, 08:33 PM
ROW '78 911 Targa
timmy2's Avatar
My 3 Snap-On torque wrenches have worked for me for 25 years without needing to be re-calibrated due to proper care and use. I have checked them regularly, and they are still 100%accurate. They will last longer than I will....
Quality and accuracy in precision tools, you get what you pay for....
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-05-2012, 08:35 PM
Racer
winders's Avatar
Like Traveller, I prefer the Precision Instruments split-beam torque wrenches....
I have the C2FR100F and the C3FR250F. I like the flex heads.
These are the same as the Snap-On torque wrenches that look like them. Just cheaper.....
Scott
Old 04-05-2012, 08:37 PM
Alps Adventurer
Traveller's Avatar
Originally Posted by timmy2 View Post
My 3 Snap-On torque wrenches have worked for me for 25 years without needing to be re-calibrated due to proper care and use. I have checked them and they are still accurate.
That is what I have, three Snap-On wrenches as well.
I bought my first one in 1975. It wasn't till I had the chance to personally calibrate it in our labs in 1992 that I knew how accurate and precise it was. Of course proper use and storage make a big difference.
In fact it was good over the full 5 to 75 lbf.ft. range and repeatability was incredible (I took 5 readings at every 5 lbf.ft over the full range). Repeatability is the most important factor. I don't care if I have to dial in 52 to get 48 as long as I get 48 every time I dial in 52...that is called repeatability and time enters into that as well. A good wrench stays in calibration.
All the best,
Alex
Old 04-05-2012, 08:45 PM
Alps Adventurer
Traveller's Avatar
Scott
I don't actually own that brand. I just recommend them since they are the same as those from Snap-On, just a bit cheaper.
All the best,
Alex
Old 04-05-2012, 08:47 PM
Regis turd ab user
Scott
I have those two as well, purchased here.Wesco Tools
Old 04-05-2012, 08:58 PM
