One ton of pressure wouldn't budge my fan
I am trying to remove the alternator from the fan on my '74S engine.
Squirted it with Kroil over a two day period then tried the zip-tie gear puller method and broke a bunch of zip-ties. Brought it to work where we have a press. Supported the edges of the fan and pressed on the shaft with 1250lbs of pressure. Didn't budge. Heated the fan around the shaft and applied 2000lbs and it didn't budge. I chickened out after that. Any ideas? TIA |
help?
Member 911 Anonymous
I can come by and show you, I just serviced mine and it seemed it would not budge but finally it let go.
PM me. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
That's a ridiculous amount of force. I hope the woodruff key is not damaged.
Wer bremst verliert
You might hit the shaft with freeze spray directly for a solid minute, while it's positioned in the press already, quickly warm the fan with some propane and turn up the pressure again right away.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Put the pressure on it and give a tap with a hammer. I had to remove a 4" diameter pin that wouldn't move with 100 tons on it until I gave a rap with a 8 pound sledge which loosened it up. I also extract 1/16" diameter brass pins when servicing the early Solex carbs using a slide hammer (a small one I made) to get these fragile pins out -works much better than just applying a simple, axial force.
Paul Abbott Weber service specialist www.PerformanceOriented.com |
fan
I have used the air hammer method on the end of the alt shaft with a small driver like you would remove a valve guide with when they are tough, the shock from the impact does wonders
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Less brakes, more gas!
Have you used the jack screw method yet? Tap 1/4-20 in the holes of the fan on opposite sides. Put 2 1/4-20 x 1" screws in the holes. Turn one a 1/2 turn then the other 1/2 turn till the fan comes off.
It is very possible that you are not pressing the shaft straight off the fan and that would make it hard to get off. This two screw technique actually rocks the fan back and fourth on the shaft which may be of help removing yours. good luck! -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Thanks for all the input guys! Still stuck, but I haven't had a chance to try all options yet. Seriously considering just cleaning and painting the damn thing while its on the alternator.
Naw. Better to get it fixed now as taking the alternator out is a pain with the fan attached. Might not even be possible...
Have you tried John Walkers method of rapping the fan housing on the edge of a step and allowing gravity to permit the alt to fall out? Go around in a circle tapping, spinning and tapping the housing until alt suddenly drops out. It works.
Ken 1986 930 2016 R1200RS |
As I read it its the fan that is stuck on the shaft, not the alternator in the housing...
air hammer. drill a divot into the center of the shaft with a semi-large bit so the hammer bit doesn't walk sideways. put the nut on the threads with a 1/8" gap to the fan hub before you kill the threads.
Oh, I did misinterpret that- thanks. For separating the ALT and fan, I used my air hammer with a pointy bit and it shot the ALT right off the fan.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Stuck fan.
Good luck, Gerry Vellios Machine Shop Home
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
FYI, finally got the thing off without breaking it.
- Put it in the freezer for several days (wife really appreciated having an alternator/fan assy next to the frozen peas...) - Then took it to work again and put it in the freezer there - Had one of my guys move it directly to a prepared setup on the press and apply pressure while heating the area around the spindle - It finally separated without damaging the fan No visible signs of corrosion or anything else that would make it stick so firmly, but it was coated with oil...the idea all that Kroil I squirted in there may have "surface locked" it could have some legs.... Anyway, thanks again for all the help and advice! John Last edited by John Mullins; 05-25-2012 at 09:22 PM.. |
