Spark Plug Socket Stuck!
Hey all,
So I was removing my spark plugs today and all was going well. . . too well! I got everything out except for plug #6. When I got to it, it didn't want to budge. I gave it a little tug but not too much force but it hardly turned. Okay, I thought, I'll just spray some PB Blast in the tube and wait, but then I realized my Spark plug socket wasn't coming out either! I tried many different extensions and even a needle nose plier but nothing can get it out! Does anyone have any suggestions? Thanks in advance, Michael
-- '87 Diamond Blue Coupe -- '92 Miata -- '06 Scion XB (the wife's) -- '01 Audi S4 (Sold) -- '17 Tesla Model S60 |
Maybe the plug socket is a little worn.
If so...try tightening a little to get the socket on the other side of the flats. A few wiggles back and forth should loosen the socket on the plug...then maybe a magnet retrieval tool to grab the socket? Bob
Bob Hutson |
what bob said, and instead of a ratchet type socket wrench used a fixed one
Try tapping it toward tight and then drawing it out with an extension or needle nose. Don't worry your engine is not doomed and it will come out eventually. Next time get a long spark plug remover (Honda mowers and power equipment come with the perfect wrench).
Leave it in there while the penetrating oil works and then use it to remove the plug. When the plug comes out the socket will too.
-Andy
72 Carrera RS replica, Spec 911 racer |
Did you try bubble gum at the end of a stick?
![]() Ehh! it'll come out. like they said.... Carl
Carl, |
take the valve cover off
It doesn't sound like you are using the factory spark plug tool. Once you get out this plug I highly recommend you purchase the factory tool. Not that expensive ( used ) and you won't have this problem again ( stuck socket ).
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Sometimes the extention will get loose in the socket...so what I do is put one piece of black tape (plastic electricians tape) on the end of the extention to tighten up the connection from the extention to the plug socket.
This will help keep the socket on when pulling on the unit. Bob
Bob Hutson |
ROW '78 911 Targa
After having to fish out othet types, I started using the factory one and it works the best of all. Almost like Porsche knew what they were doing! :-)
Sugar Scoops Rule :)
Does our host sell the spark plug tool? (I don't see it on the 'tools' page of the parts catalog)....
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
the one from Hazet works wonderful. get it from Zelenda. http://www.zelenda.com/
Well to update on my situation, I have tried all day to free the socket with no luck. The only things I have to show for today's effort are a few bruised knuckles. I think what I'll do tomorrow id run to a tool store and buy a locking socket extension, something like this: Amazon.com: Neiko Pro-Grade Locking Extension Bar Set - No More Dropped Sockets!: Automotive . Perhaps that will do the trick!
After I get the socket out I will buy the Hazet tool and try again to remove the plug. Thanks for all the feedback, -Michael
I dropped the spark plug in mine once and worked on it for an hour before pulling the valve cover which is what I should have done from the very start. Pulling the valve cover gives you full access and you can see what you are doing thus causing no damage.
89 930 Cab Black 11 Cayenne |
Removing the valve cover was the first thing I did. The problem is since it's cylinder 6, it's all the way at the front so you really can't see down there without a inspection mirror and a flashlight. My problem isn't that the the socket is dropped in the tube, it's full on stuck!
-- '87 Diamond Blue Coupe -- '92 Miata -- '06 Scion XB (the wife's) -- '01 Audi S4 (Sold) -- '17 Tesla Model S60 Last edited by fxeditor; 04-08-2012 at 04:40 PM.. |
6 cylinder symphony
Yeah - you don't need this, but I like the tool from the tool kit so much, I bought a spare one off the board, and it sits in my tool box.
Good Luck. If it got stuck while trying to remove the plug - try to go the other way again. Wiggling it helps. And shoot more PB down there.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
Spiderman
What ruferst..... said above. I quit using my "fancy" socket set sockets for spark plugs and use the one in my OEM tool pouch. Might as well use it, they gave it to you ! Works great and will never have your problem. The flexi-feature and knurled nut thats easy to turn with your fingers is perfect to get them started without cross-threading.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
6 cylinder symphony
Watch the board and e-bay. They come up for sale all the time.
Buy two - one for the tool bag, one for the tool box!
Thread Tools | |
Rate This Thread | |
