1987 Carrera
Running Lights Out
Hi,
When I turn on the the head lights in my 911, the driver side front and rear running lights don't light up, but the passenger side ones work. The headlights are fine. Actually, there is an issue with the high beams that's related to the blinker, but I don't think the problems are related.
Where do I start looking? Fuses? If so what fuse??
Thanks!
Ace
Ace123
1987 Porsche 911 Coupe
Old 04-13-2012, 11:53 AM
Porchcar guy's Avatar
Look at the grounds for the running lights. happened to me a few months ago.
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 04-13-2012, 01:33 PM
1987 Carrera
How do I check that? Do I unscrew the lights and then see what's going on inside. Maybe clean the connections and make sure they are secure?
Ace123
Old 04-16-2012, 11:33 AM
Look behind the light assemblies inside the engine area for the grounds but also check the connections. You might pull the assemblies and clean all.
15 year PCA member
Old 04-16-2012, 01:28 PM
I would check a fuse for the running lights. I think the left and right sides are on seperate fuses. I don't have a diagram but I think the first 8 fuses are for the exterior lights.
Bad grounds are also a very common issue with all lights.
Old 04-16-2012, 06:09 PM
muck-raker
kidrock's Avatar
probably a fuse, the driver's side runs on a different system than the passenger's side. I don't know which fuse....you'll have to open up the hood and physically inspect each fuse.
Another factoid: the light under the engine bonnet is a common source for this problem. The light becomes old and baked, along with the wiring to it. When it goes bad or shorts out, it will cause the exact issue you are describing. It can be fixed or replaced, but the new fixture is a little spendy.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-16-2012, 07:24 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Driver's side running lights.
As per kidrock, your problem is most likely a blown fuse,
due to a shorted engine compartment light switch.
Hope this helps.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-17-2012, 03:46 AM
