81SC CIS part identification
Need confirmation on parts here.
The bottom valve is the deceleration valve, or the AAV? I'm trying to troubleshoot an intermittent high idle (2100rpm), I've read a few threads and was experimenting with pulling the vacuum line but couldn't work out if I had the right one.
Old 08-16-2015, 03:20 AM
The lower pod has a vacuum connection on the outside. Many times I find the line disconnected and plugged.
Bruce
Old 08-16-2015, 04:46 AM
Yes, it has a vacuum line. Is it the deceleration valve?
Old 08-16-2015, 04:56 AM
gregoryp's Avatar
Aav
That is the auxiliary air valve. Check out this web site. Has a great description of everything. 911 CIS Primer - Index
79' 911 Targa
07' Cooper S
03' E46 M3 sold
96' E36 M3 sold
81' XS-650 Bobber sold
Old 08-16-2015, 05:01 AM
El Duderino
tirwin's Avatar
The one with the vacuum line is the decel valve.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 08-16-2015, 06:36 AM
Here is another view of an engine similar to yours
You can see the AAV and decel valves look nearly alike, but the decel valve has the vacuum port on the front. In your photo, you can see the port at the very right side of the valve, identifying it the decel valve. The two valves in the picture are in reverse location to yours--your upper valve is the AAV and the lower is the decel.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 08-16-2015, 08:07 AM
Ah, thanks for this. The descriptions I have seen/read match your picture, with the decel valve on top, but mine has the decel valve on the bottom.
I wonder why mine would be around the wrong way then? I suppose someone might have a reassembled them incorrectly. If that is the case, then I wonder if that is causing an issue?
Old 08-16-2015, 03:21 PM
Here is a picture of a set up like yours, from a 1981 SC
and a picture of how the devices are connected
You'll notice both devices connect to the metal tubing, and both connect to a molded rubber fitting. In short, it wouldn't matter if the devices were switched as both are connected to the same vacuum system.
L.J.
Old 08-16-2015, 06:25 PM
Gotcha, thanks. I notice that last picture looks like it has had the 'crush' treatment for the decel valve.
Not sure if I am going to try plugging the vacuum or try the crush treatment.
Old 08-16-2015, 09:03 PM
Also check the that the advance is not sticking in the distributor.
Old 08-16-2015, 09:14 PM
Any advice on how to do that?
Old 08-17-2015, 05:00 AM
Bump in the off chance that someone can answer this Q
Old 08-17-2015, 06:51 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Your's is not on the wrong way, The decel is on the bottom. Without a doubt. Word to Your Mother, as Vanilla Ice says.
Lemmie get a pic.
1981 911SC Targa
Old 08-17-2015, 07:12 PM
Bob Kontak's Avatar
Chill on this for now. You gots you some vacuum advance and mechanical advance. Both can be tested. You have a timing light?
1981 911SC Targa
Old 08-17-2015, 07:14 PM
Actually I don't think I do. I did have once, long ago when the earth was green and children respected their parents. This is the way to test, with a timing light? Maybe I can find one somewhere.
Old 08-17-2015, 07:22 PM
Bob Kontak's Avatar
Ossiblue's second pic is correct.
1981 911SC Targa
Old 08-17-2015, 07:30 PM
So I golf tee'd the vacuum line and the driveability of the car at low speed is transformed. It's like it had three flywheels in it before.
Old 08-22-2015, 03:40 PM
