anatomy of a Beru spark plug connector
What they didn't teach you in Biology class:
Jeff Keyzer 72 914 w/2056 built by Mark DeBernardi @ Original Customs Megasquirt with MSII upgrade |
Man, the information on this site just never stops. I learn something new everyday.
Senior Member
Excellent work, Mr. Keyzer!!
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Schleprock
So, I assume the part of the connector that has been known to be troublesome/fail is the resistive coil?
Thanks for the cutaway view!
Kevin L '86 Carrera "Larry" |
Thanks Jeff! Always wondered what they looked like inside...
I am not 100% sure, but I speculate what causes these connectors to become intermittent are the spring loaded connections between each of the pieces. Nothing is soldered together so if a small amount of moisture gets in there all of the contact surfaces are going to oxidize a little bit and start making poor electrical connections. Because it's all held together by a spring, vibrations can cause the pieces to shift around slightly and possibly give erratic results. The coils themselves tested ok on both of the Berus I took apart.
How did you cut the thing open?
I have a coupla bad ones at home and wouldn't mind pulling them apart to try and find the problem. Cam
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
You can slice them open with a dremel tool. We sliced one side mostly open with the dremel and then squished the connector in a vice to split it open. Watch out for flying parts.
Looks like ssomething from a Model A, or maybe a Farmall tractor. Makes me all the happier to be using Magnecor connectors.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Me too. No silly connectors, no silly grounded braid. They just work.
