Sox Fan's Avatar
List of Possible mods for G50
Now that I have owned my 911 for about six months, I have the mod bug. Love the car but I want more throttle response, smoother/quicker shifting and more exhaust sound. The car is fun the drive but I am honestly just a little underwhelmed. The plan is to keep the car looking stock but do some reversible mods to make it more fun to drive. The car is a coupe with 42,000 miles and is in very nice original condition. Here is what I am looking to do - any/all feedback appreciated.
JWest G50 short shift kit.
Steve Wong Chip
Fabspeed Euro pre muffler/cat delete.
Fabspeed Supercup exhaust.
The only part I am really debating is the muffler. Not sure how loud to go. I really want to hear it but wonder if the Super Cup will be too much. Car is used for weekend rides and I commute with it a couple of times a week during the warm weather months.
1989 Carrera
Old 06-08-2013, 06:15 AM
ganun's Avatar
All that and still have a 1 in muffler??.....let it breathe and put SSI or headers.
Check out the sound, "PCA Sebring Blast" on YT.
Old 06-08-2013, 06:25 AM
(man/dude)
Jonny042's Avatar
+ 1 One the SW chip. You will be whelmed.
Old 06-08-2013, 06:29 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Chip replacement definitely improves the throttle response. Still, the throttle response is physically/mechanically hindered by the clutch. The G50 clutch is a whopper heavy. Changing to a lightweight aluminum alloy clutch helps a ton
Honestly the shifter isn't going to help with smoothness. That is, unless there's some worn bushings in the shifter assembly. Bumpy shifting is often worn synchronizer assembly in the trans. Or, old gear oil that hasn't been changed in who knows how long.
Kevin L
'86 Carrera "Larry"
Old 06-08-2013, 07:35 AM
Recreational User
porschenut's Avatar
Short shift kit is not going to make shifting smoother or faster, it will just make it travel slightly less and require more effort.
For throttle response, the chip will make a difference. If you really want to wake the car up, change the 9/31 ring and pinion to an 8/31, if that's possible.
I'd also echo the suggestion to go with headers and a 2-in muffler, but not SSIs. SSIs have a 1.5" primary and are too small for 3.2L. They were designed for 2.7L engines, and help a bit on the 3.0 but they're too small for anything larger. You want 1 5/8" primaries on a 3.2.
Old 06-08-2013, 11:38 AM
kuehl's Avatar
3.5 Nickies, 9.5:1
Supercharger 8 psi
Wideband O2 Display
Kuehl Air Conditioning
Change 1st gear to 3.0
Kennedy Clutch
Old 06-08-2013, 09:31 PM
My 88 has the following: Steve Wong chip, JWest G50 short shift kit, M&K pre-muffler, and M&K 1in/1out muffler. The chip makes a big difference and is well worth the money. The JWest kit made a big difference in shift quality for me, shorter more precise. I had a few other mufflers on the car and by far I prefer the M&K with the pre-muff. Sound is just right, not too loud. There are other threads on this. This all works for me. Maybe different for you. If I wanted to spend the $$$ I would go the 3.5 route.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 06-09-2013, 04:32 AM
Sox Fan's Avatar
Originally Posted by kuehl View Post
3.5 Nickies, 9.5:1
Supercharger 8 psi
Wideband O2 Display
Kennedy Clutch
Supercharging a 3.2 is an interesting idea. What manufacturer would you recommend? Paxton? Any experience doing this? I googled a bit and see very little on supercharging 3.2 Carreras.
1989 Carrera
Old 06-09-2013, 07:53 AM
Sox Fan's Avatar
Sounds like you have gone pretty much the same route I am considering. Just debating how aggressive an exhaust to get. The Supercup is more aggressive than most sport mufflers. I have also considered just getting a euro pre muffler/cat delete and the chip first and seeing what that does. Those two may have the most bang for the buck.
Any regrets with what you have done? Is the car just a bit more enjoyable to drive or much more fun?
1989 Carrera
Old 06-09-2013, 07:56 AM
kuehl's Avatar
We'll PM you. Don't want to steal the thread
Old 06-09-2013, 08:01 AM
KTL KTL is offline
Schleprock
KTL's Avatar
For your intended purpose/use, I think the cat eliminator/premuffler and a sport muffler is fine. You won't feel a ton of gains with headers w/out doing some tuning. If you want improved sound and some additional pep, uncorking the stock exhaust with a premuffler and sport muffler does the job nicely.
The sport muffler is key to getting an improved tone. The stock banana muffler does a very good job of reducing the sound on the engine. If you watch from the side of the road a stock 911 Carrera 3.2 or SC blow by you at high rpms, what you hear most of is fan noise and wind noise. The exhaust noise is more of a whooshing blowing sound.
Considering aftermarket mufflers are so expensive, our group of guys decided that's just too hard a pill to swallow- $700+ for a new muffler. No thanks. We found a decent sized universal muffler from Dynomax and had some pipes bent to fit it at a friend's Meineke repair shop. Made a hanger bracket with some angle steel along with large band clamps around the muffler case (like B&B or M&K style) and worked pretty good. Sounds sorta like a small V-8?
NASA Autobahn MW GL TT Elbow Otto Ride 9 12 10 - YouTube
Kevin L
'86 Carrera "Larry"
Old 06-10-2013, 08:39 AM
kuehl's Avatar
Kevin,
Have you seen/heard a 'dual out' that does not have resonance?
Old 06-10-2013, 08:56 AM
KTL KTL is offline
Schleprock
KTL's Avatar
No I haven't seen one myself. Seems to be a fairly prevalent thing for our engines.
I recall Jack Olsen went so far as to cut the collectors off his B&B headers, shorten the pipe lengths, reattach collectors, then install a dual in dual out crossover style muffer (rectangular muffler like used on Buick turbo V-6) and install smaller tailpipes to tune the sound. He posted his work in a detailed fashion like he always does.
Also I think the Triad West muffler system might have been a good system to arrest resonance. Do a search for that too.
Kevin L
'86 Carrera "Larry"
Old 06-10-2013, 09:49 AM
Sox Fan's Avatar
Thanks Kevin. Definitely not interested in more than a couple of simple bolt ons. Now really just debating what muffler to use, how loud/aggressive.
1989 Carrera
Old 06-10-2013, 05:35 PM
Sox Fan's Avatar
Took the plunge.
After reading lots of reviews and youtube clips, settled on M&K one in/one out muffler and pre muffler. Then ordered a Steve Wong chip for it. I was afraid the Supercup exhaust might be too loud for me. I will get this stuff installed and then maybe do the short shift kit after. M&K seems to get really strong reviews and their sport muffler seems to be on the aggressive side without being obnoxious.
Can't wait to see what this does to me car. I will post again once it is all in.
1989 Carrera
Old 06-11-2013, 08:04 AM
