-   -   Newest Trend in 911 Modifications. The DUALLY! (http://forums.pelicanparts.com/porsche-911-technical-forum/670819-newest-trend-911-modifications-dually.html)
diverdan 04-11-2012 01:24 PM
Guess they don't drive it because that set up would probably blow the tires as they would rub together. At least they would under load. There is a reason to keep the tire walls from rubbing. However, long live creativity!
Dan
Cory M 04-11-2012 04:05 PM
if I convert my racecar maybe I won't have to take points for widening the rear wheels?
Noah930 04-11-2012 04:13 PM
Very good point.
Q: Are tires or wheels wider than stock?
A: Nope. [snicker]
Craig T 04-11-2012 04:27 PM
Cory, the GCR's only state wheel width, there is nothing about how many rear wheels you can use. I think you should dual-up a set of 9"s. That puppy would really stick with 18"s of rubber on the ground. That would catch Sheriff Parker at a loss for words.
FrenchToast 04-11-2012 04:35 PM
This is the kind of thinking that racing needs! Jim Hall and Norbert Singer must've thought this way. Was it the Chaparral 2D, where they needed a minimum luggage space (like the spare tire - weird rule) so Jim Hall grafted in a bunch of small storage containers in most or all of the body work, and it added up to the minimum!
I remember the prototype for the 917/10 ran duallies in the rear, since at the time there weren't tires wide enough to handle the power! :eek:
Take care
HFR_Racer 04-12-2012 05:29 PM
I thought that everyone was upgrading to the Super Single??
DohertyCM 04-12-2012 05:39 PM
I got it
Well, its an interesting Idea....
But..
They need a spacer between the wheels to get a wider stance....
I think its a VW Kit Car...
Richard930 04-12-2012 05:51 PM
Pretty sure I remember that car from a Miami Vice episode in '85 or so!
Danny_Ocean 04-12-2012 06:47 PM
Meh...BMW's got it beat:
http://www.pyropedonecrophilia.com/p...ino_dually.jpg
