1974 911 w/ 83 SC engine
Are there any headers for an SC that don't require new oil lines?
I have an '83 SC motor in a '74 chassis, and want to replace the heat exchangers with headers. It seems every aftermarket header I see requires swapping the hard oil line for a pre-74 one, which I then read is a major PIA. So, are there any headers out there that DON'T require a new oil line? Thanks!
Old 12-01-2012, 09:12 PM
Senior Advisor
James Brown's Avatar
rarlyl8t sels them, on this forum they are great
08 Cayenne Turbo
Old 12-01-2012, 09:41 PM
Elombard's Avatar
I am about to do tis but had not heard it was a PITA? Is the problem getting the oil lines loose?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-02-2012, 02:18 AM
cdrik915's Avatar
Anyway , stock oil lines can be bended to fit correctly without touching the headers.
Heat sheet is recommended to prevent excessive temp'.
LIGHTER = FASTER !!!
Old 12-02-2012, 03:37 AM
I've read removing and re-installing the oil line where it meets the engine in the rear is difficult, but the oil line issue is always overshadowed by "snapping exhaust studs" when people bring up potential header swap problems.
Old 12-02-2012, 09:14 AM
Hard to do with the headers in place, but doable if you're replacing the headers.
Old 12-02-2012, 10:11 AM
Elombard's Avatar
Yah I just finished with the removing the heat exch battled the nuts and studs) and was going to tackle the oil line today. I think with the exh off it wont be too bad.
Old 12-02-2012, 10:25 AM
