1974 911 w/ 83 SC engine
Are there any headers for an SC that don't require new oil lines?
I have an '83 SC motor in a '74 chassis, and want to replace the heat exchangers with headers. It seems every aftermarket header I see requires swapping the hard oil line for a pre-74 one, which I then read is a major PIA. So, are there any headers out there that DON'T require a new oil line? Thanks!
Senior Advisor
rarlyl8t sels them, on this forum they are great
08 Cayenne Turbo |
I am about to do tis but had not heard it was a PITA? Is the problem getting the oil lines loose?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Anyway , stock oil lines can be bended to fit correctly without touching the headers.
Heat sheet is recommended to prevent excessive temp'.
LIGHTER = FASTER !!! |
Hard to do with the headers in place, but doable if you're replacing the headers.
Yah I just finished with the removing the heat exch battled the nuts and studs) and was going to tackle the oil line today. I think with the exh off it wont be too bad.
