porwolf's Avatar
Congratulations, you nailed that reawakening thing. I can see how that car with that color and that finish keeps inspiring you. Must be a great thrill to run it through the neighborhood and then far away! I don't drive mine very much, but when I do it's always like the first time! Love it!
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 04-19-2012, 01:20 PM
I live in Charlestown, about 30 to 35 minutes away. Is that your garage in those pics of your car?
Old 04-20-2012, 08:10 AM
Detached Member
Hugh R's Avatar
Nice, I feel bad when mine sits for a month due to travel for work. Gonna run some errands in it this morning.
Hugh
Old 04-20-2012, 08:40 AM
matt gineo's Avatar
Is that Charlestown RI or Mass? I took the photo at Jake Kaplan's Jag dealership in RI. where it sat for 16 years. It was taken just before I bought the car and before any cleaning, detailing work. It's in my garage in Newport right now and will start cleaning her up as soon as I finish the brakes. Will post some pics after I buff it out. I have a 120 x 100 ft garage with a machine shop, welding shop, wood shop etc. We build our boats in the shop from December through April then it sits empty for 7 months.
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 04-20-2012, 09:18 AM
Sugar Scoops Rule :)
dave 911's Avatar
Awesome!! Congrats, and it's great to have another 76 targa on the board !
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 04-20-2012, 10:33 AM
matt gineo's Avatar
Thanks Dave, Love your color!
1962 356 C- sold
Old 04-20-2012, 10:40 AM
matt gineo's Avatar
After 18 years she's on the road again!! Took her out for a short, slow drive today and everything seems ok. Need to do a little brake work then off to the Highway!
1962 356 C- sold
Old 04-29-2012, 05:57 PM
Pure Awesomeness
szyzygy's Avatar
Good job on the pre-work. Love the color.
Nice to see another old Porsche still on the road after all these years!
1977 Porsche 911
Old 04-29-2012, 06:04 PM
Navin Johnson
TimT's Avatar
Pretty car.... though it need to lose the "Paris-Dakar" look
'69 911 GT-5
'75 914 GT-3
and others
Old 04-29-2012, 06:09 PM
matt gineo's Avatar
Do you know what the original US spec ride height is and how much it should be lowered? I don't want it too low as I have heard about cars bottoming out on small speed bumps, driveways etc. How do you measure the ride height , from the bottom trim of the fender to the ground?
I'm not sure what size tires are on the car now. That's the next thing I'll be replacing.
1962 356 C- sold
Old 04-30-2012, 05:48 AM
cdrik915's Avatar
Congrats !!!
The color is not usual , i've never seen a 911 with this paint .
Amazing !!!
LIGHTER = FASTER !!!
Old 04-30-2012, 07:41 AM
Divedeep's Avatar
I am happy for you! Lower the body a bit more, she is to high for my taste.
Rest is supreme!!!
Have fun!
Michael
1966 911 2.0
1980 SC Targa
Old 04-30-2012, 07:58 AM
Porsche measures the ride height by calculating the difference between the center of the wheel and the center of the torsion bars. That way, the diameter of the tires has no bearing on the issue. The US ride height varied over the years; I'd suggest using the "ROW" spec from that era. If you buy a "Porsce technical specification" book for that year, it will have the numbers you need.
2 cautions: 90% of the people here will tell you to measure the height to the bottom of the fender wheel openings. Not an accurate way to do it... The same 90% will offer measurements of "euro" or "ROW" height that are actually lower than what they should be.
The front end of your car may be higher than ususal, if the fuel level is low. These cars drop a noticeable amount in the front when you add fuel. You might also check to see if there is a 5mm thick spacer at the top of the front struts, under the fender. Porsche installed these on some models (various years) to raise the front end to meet DOT regulations and while keeping acceptable front suspension kinematics. I don't recall what year they started doing this, so check your car and remove them if you have them, before you adjust the suspension. When you do adjust it, have it done at a shop that is very familiar with these cars and make sure that they weigh each corner and set the corner weights correctly. Having the corner weights within specifications is a little more important than having dead even ride heights from side to side.
Have fun,
JR
Old 04-30-2012, 08:31 AM
Realy great looking car,
Well done on the re-awakening, good luck with it.
Anthony.
Old 04-30-2012, 08:34 AM
matt gineo's Avatar
Have fun,
JR
Thanks for the great info. I took the photo while everything was out of the trunk for cleaning, spare tire, tool kit and jack, fuel tank was about 1/4 full. I'll make sure to load it back up before taking any measurements.
1962 356 C- sold
Old 04-30-2012, 09:25 AM
Functionista
manbridge 74's Avatar
Seconding javadog here.
Perhaps this car had 16" wheels or larger OD tires on it at some point? Just put 15" rims back on mine and had to lower front by two turns to return to same height as with 16" wheels.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 04-30-2012, 10:27 AM
matt gineo's Avatar
Originally Posted by cdrik915 View Post
Congrats !!!
Amazing !!!
Thanks, I'm pretty sure it's Peru Red.
1962 356 C- sold
Old 04-30-2012, 12:49 PM
matt gineo's Avatar
I was finally able to take her out for a real ride yesterday, new tires, good brakes, gearbox and suspension. At first there was a little hesitation during slow acceleration, after running seafoam and a tank full of gas I replaced the fuel filter and now she's running like a champ! Pulling strong, no smoke or oil leaks.
I still have a few odds and ends to take care of, lower stance, remove thermal reactors etc. but I'm going to enjoy it this summer and get back to business this winter.
I thought the color was Peru Red but after checking the paint code I found that it's actually Sienna Metallic.
Thanks to all my fellow Pelican's who helped me get her running again!
1962 356 C- sold
Old 06-16-2012, 07:01 PM
HarryD's Avatar
Great story.
If it was me I would make point of getting rid of the thermal reactors ASAP.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-16-2012, 09:20 PM
where are the links to 4 barrell carb set up with plentum....design....intke adjustments...etc
Old 06-16-2012, 09:23 PM
