Congratulations, you nailed that reawakening thing. I can see how that car with that color and that finish keeps inspiring you. Must be a great thrill to run it through the neighborhood and then far away! I don't drive mine very much, but when I do it's always like the first time! Love it!
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
I live in Charlestown, about 30 to 35 minutes away. Is that your garage in those pics of your car?
Detached Member
Nice, I feel bad when mine sits for a month due to travel for work. Gonna run some errands in it this morning.
Hugh |
Is that Charlestown RI or Mass? I took the photo at Jake Kaplan's Jag dealership in RI. where it sat for 16 years. It was taken just before I bought the car and before any cleaning, detailing work. It's in my garage in Newport right now and will start cleaning her up as soon as I finish the brakes. Will post some pics after I buff it out. I have a 120 x 100 ft garage with a machine shop, welding shop, wood shop etc. We build our boats in the shop from December through April then it sits empty for 7 months.
1976 911 Targa 2.7 CIS Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior 1963 356 SC- crashed ![]() 1962 356 C- sold ![]() 1965- 912- sold- fun but too slow |
Sugar Scoops Rule :)
Awesome!! Congrats, and it's great to have another 76 targa on the board
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
Thanks Dave, Love your color!
After 18 years she's on the road again!! Took her out for a short, slow drive today and everything seems ok. Need to do a little brake work then off to the Highway!
Pure Awesomeness
Good job on the pre-work. Love the color.
Nice to see another old Porsche still on the road after all these years!
1977 Porsche 911 |
Navin Johnson
Pretty car.... though it need to lose the "Paris-Dakar" look
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Do you know what the original US spec ride height is and how much it should be lowered? I don't want it too low as I have heard about cars bottoming out on small speed bumps, driveways etc. How do you measure the ride height , from the bottom trim of the fender to the ground? I'm not sure what size tires are on the car now. That's the next thing I'll be replacing.
Congrats !!!
The color is not usual , i've never seen a 911 with this paint . Amazing !!!
LIGHTER = FASTER !!! |
I am happy for you! Lower the body a bit more, she is to high for my taste.
Rest is supreme!!! Have fun!
Michael_____________________________________________ 1966 911 2.0 1980 SC Targa |
2 cautions: 90% of the people here will tell you to measure the height to the bottom of the fender wheel openings. Not an accurate way to do it... The same 90% will offer measurements of "euro" or "ROW" height that are actually lower than what they should be. The front end of your car may be higher than ususal, if the fuel level is low. These cars drop a noticeable amount in the front when you add fuel. You might also check to see if there is a 5mm thick spacer at the top of the front struts, under the fender. Porsche installed these on some models (various years) to raise the front end to meet DOT regulations and while keeping acceptable front suspension kinematics. I don't recall what year they started doing this, so check your car and remove them if you have them, before you adjust the suspension. When you do adjust it, have it done at a shop that is very familiar with these cars and make sure that they weigh each corner and set the corner weights correctly. Having the corner weights within specifications is a little more important than having dead even ride heights from side to side. Have fun, JR |
Realy great looking car,
Well done on the re-awakening, good luck with it. ![]() Anthony. |
Functionista
Seconding javadog here.
Perhaps this car had 16" wheels or larger OD tires on it at some point? Just put 15" rims back on mine and had to lower front by two turns to return to same height as with 16" wheels.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Thanks, I'm pretty sure it's Peru Red.
I was finally able to take her out for a real ride yesterday, new tires, good brakes, gearbox and suspension. At first there was a little hesitation during slow acceleration, after running seafoam and a tank full of gas I replaced the fuel filter and now she's running like a champ! Pulling strong, no smoke or oil leaks.
I still have a few odds and ends to take care of, lower stance, remove thermal reactors etc. but I'm going to enjoy it this summer and get back to business this winter. I thought the color was Peru Red but after checking the paint code I found that it's actually Sienna Metallic. Thanks to all my fellow Pelican's who helped me get her running again!
1976 911 Targa 2.7 CIS Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior 1963 356 SC- crashed ![]() 1962 356 C- sold ![]() 1965- 912- sold- fun but too slow Last edited by matt gineo; 06-16-2012 at 07:04 PM.. Reason: typo |
Great story.
If it was me I would make point of getting rid of the thermal reactors ASAP.
where are the links to 4 barrell carb set up with plentum....design....intke adjustments...etc
