Porsche engine number help
Can some please give me a range of matching engine numbers for a 1972 porsche 911t with a vin number 9112110114.
Thank you
Old 11-13-2008, 03:15 PM
3.2 CAB's Avatar
It looks like that VIN would have engine numbers, 6129001-6129293. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-13-2008, 09:27 PM
I think those number ranges are for a sporto engine (911/61 engine type). The 2.4 liter 911T with MFI , engine type 911/51 will have engine number range 6120001 to 6124478.
Tony G
2000 Boxster S
Old 11-14-2008, 05:07 AM
Grady Clay's Avatar
vnm007,
You got TWO correct answers to your question.
9112110114 decodes as:
911 = Vehicle model (911 group).
2 = Model year 1972.
1 = Engine type 911T-E.
1 = Body version Targa
0144 = Sequential number.
The engine type 911T-E is the designation for 1972 or 1973, 911T, 2.4 l (2341 cc, 140 hp, MFI). The engines can be either type 911/51 for USA 4-speed or 5-speed equipped or type 911/61 for Sportomatic equipped.
If the engine is type 911/51 then the range of engine numbers are 6120001 to 6124478 (4478 total).
If the engine type is 911/61 then the range of engine numbers are 6129001 to 6129293 (293 total).
These engine numbers decode as:
6 = Engine designation, 6-cylinder unit.
1 = Engine type, 911T-E (1972 or 1973, 911T 2.4 l [2341 cc], 140 hp, MFI).
2 = Model year, 1972.
0, 1, 2, 3 or 4 for engine type 911/51 for manual transmission; 9 for engine type 911/61 for Sportomatic transmission.
xxx = sequential number.
The transmission types used with each engine type are:
For 911/51 are 915/00, 915/01, 915/02, 915/03, 915/10 and 915/12.
For 911/61 is 925/00.
Transmission numbers decode as:
7X2xxxx;
7 = Transmission for 6-cylinder.
X = 2 for 4-speed, 3 for 5-speed, 6 for Sportomatic 925/00.
xxxx = Sequential number.
Sources: Spec book – 4220.20 (X/73); Service Information USA Model 1972, (IX/71); Factory Workshop Manual 4805.20, Vol IV, Group 3, revision XXXV.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 11-14-2008, 06:57 AM
Originally Posted by Grady Clay View Post
vnm007,
7X2xxxx;
Best,
Grady
Hey Grady...is that a $1.25 answer or a $12.50 answer?
Tony G
2000 Boxster S
Old 11-14-2008, 07:04 AM
Grady Clay's Avatar
Best,
Grady
Old 11-14-2008, 07:10 AM
Thanks guys,
I got my red book now so I can check everything.
Vik
Old 11-15-2008, 12:27 PM
Send a message via Skype™ to Volz
Porsche Crest
I'm looking at buying an engine and the seller just gave me the engine number as he's not sure if it's a 2.7 or 3.0...
OE 320146S
Does that mean anything?
Thanks guys
Old 08-07-2010, 10:31 AM
OE 320146S
Thanks guys
that's not a proper number. should be 7 digits...all numbers for a 2.7 or 3.0 up to 1981. For the 82 and 83 3.0's it was 8 didits... 2 numbers 1 letter and 5 more numbers.
Tony G
2000 Boxster S
Old 08-07-2010, 10:45 AM
Out Of Control
FirstPorsche's Avatar
Engine number Range for . . .
Seems like you guys on this thread might know how to answer my question. Bought a 2002 C4S with a bad IMS bearing which F'ed up the engine. I brought it to a "rebuilder" and didn't write done engine number. I'm worried I may not get MY engine block back. My vehicle's VIN is WP0AA29942S623580 - Can someone tell me the Engine number range for it? Is there anyway to know if I got the "matching" engine block back? I don't know if the newer cars can be deciphered like you guys did with these older one.
Thanks!
"LIFE'S JOURNEY IS NOT TO ARRIVE AT THE GRAVE SAFELY IN A WELL PRESERVED BODY, BUT RATHER TO SKID IN SIDEWAYS, TOTALLY WORN OUT, SHOUTING ...HOLY ****....WHAT A RIDE!"
Old 04-18-2012, 11:31 PM
smooth's Avatar
Which brings us to the next mystery engine # from a 1973 1/2 T with VIN #9113112067 and engine # 6133169 type 911/91. PCA says it's not the correct eng. # I've been told but I can't confirm that because I'm in Puerto Rico and they won't give info out unless you have a stateside address/phone #. A friend of mine in the States actually got the info over the phone. I believe it is the correct # as there are so few of these out there. Any ideas? Thanks.
Old 04-19-2012, 09:57 PM
djpateman's Avatar
type 911/91 starts at 6133001 <> 6136092
6133169 is # 169 out of 3092 thus very early
9113111001 9113112302
9113112067 is # 1067 out of 1302 thus very late
to match the engine should be in the 61354xx range
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-20-2012, 06:14 AM
smooth's Avatar
Thanks, that sheds some light on it. More research needed.
Old 04-20-2012, 08:02 AM
Grady Clay's Avatar
smooth,
I find it offensive that PCNA doesn’t respect Puerto Rico as USA.
If you have a problem with them not responding, please tell me. I’ll make them understand.
Best,
Grady
Old 04-20-2012, 08:36 AM
Thanks!
The original engine to your vehicle should be:
M96/03 66223715
Original transmission number:
G9631 1007555
Old 04-20-2012, 10:57 AM
Out Of Control
JRBennett - Thanks for the Info. I'll use that when I pick up my disassembled engine. I asked that he not put anything back together or crate anything so I can carefully inventory the parts. May I ask where you got the information?
Thanks again!
Old 04-22-2012, 04:38 PM
