1985RedTarga's Avatar
Heater fan does not work AND its WINTER
Ok, fairly new to Porsches. I'm still getting used to the heating system. It's my understanding that you pull the 2 levers up and it opens the heat exchangers to bring heat forward. It does just that. Now, when I turn the dial thats right there, nothing happens. I've been told that this is a fan switch that will blow all that hot air.
I need to boost the air flow. I checked the fuses in the engine compartment and they look good. Where do I start to check? Anyone with experience on this topic?
This is a 85 Targa, not the auto heat type.
Thanks!!
Jamie
1985 911 Targa
Old 01-27-2012, 04:58 PM
RETIRED
Joe Bob's Avatar
Put power to the fan direct to test....if it works it's likely the footwell blowers have issues or the switch between the seats.
2012 ML350 3.0 Turbo Diesel
Old 01-27-2012, 05:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 what Joe Bob wrote
or
turn the key to ignition, then pull the red levers up and the engine blower motor should turn on.
If not, the switches at the levers are not making contact. The switches are connect to a copper contact and when the levers are up, the contact is switched or should be.
If the switches are making contact and the motor is running, turn the dial to 2 or 3, the foot blower should kick in, if not the blower motor/s may be shot.
Hope this helps.
If all motors work, then get under the car and ask a helper to raise and lower the levers, the flaps should open and close fully, if not adjust, using a needle nose and 8MM socket, you may need to spray some lube to loosen the nut, they tend to rust lock.
'85 Carrera Targa
PCA/POC
Old 01-27-2012, 05:21 PM
j911brick's Avatar
Doesn't the left flapper box have some kind of senor in it?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 01-27-2012, 10:20 PM
Thanks. Gives me some place to start.
12 volts to the blower fan i guess???
Jamie
1985 911 Targa
Old 01-28-2012, 05:22 AM
RETIRED
Joe Bob's Avatar
Yup....I would pull it and bench test.
Old 01-28-2012, 09:28 AM
Ok, pulled the fan from the engine compartment today and hooked it up to DC. Worked fine. The fuse in the engine compartment is still good. Where should I go from here???? Could it be the rotary switch?
And how does one turn on the footwell blowers???? While I love my car, the heating system is confusing as all get out!!
Jamie
1985 911 Targa
Old 01-30-2012, 02:08 PM
In maintenance phase
daniel911T's Avatar
Obligatory smart ass answer: Backdate. The engine mounted fan rarely fails.
Back to real troubleshooting.
-Dan
1969 911T (Getting a 72E heart transplant)
2004 Volvo XC70
Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s.
Old 01-30-2012, 07:31 PM
FrinkFrog's Avatar
Send a message via AIM to FrinkFrog
If the '85's are like the '83's, couldn't the problem maybe have to do with the blower fan in the dash... located on the firewall in the trunk compartment? I had to service mine with lubrication after it began squealing loudly (and according to members of this bb... before its ultimate failure w/out maintenance). Can Jamie check that fan the same way he checked the fan in the rear engine compartment?
'83SC
'76 911S - Sold.
Old 01-30-2012, 08:04 PM
DRACO A5OG's Avatar
Okay now check the two levers at the e-Brake. Make sure switches engage when you lift up on the levers. Switches are connected to yellow wires.
'85 Carrera Targa
PCA/POC
Old 01-30-2012, 08:47 PM
Draco, they do make contact. Now where?? lol
Jamie
1985 911 Targa
Old 01-31-2012, 05:06 AM
aj88cab's Avatar
If the contacts are good, I'd suggest your next check would be to find a local owner of a similar Carrera thru Pelican or PCA that has a know working heater system and switch out the heater control unit to test. My experience has been that more times than not, it is a bad controller unit. It is located on the relay panel in the engine compartment.
The footwell blowers will not run if the engine blower doesn't run. If you get the engine fan to run with a good controller unit, you may find issues with the footwell blowers. If they haven't run in a while they are prone to problems. You could bench test them in the meantime.
Also, there are two fuses on the engine comparment fuse block associated with the heater system. One for the engine blower fan, the other is power for the controller unit. You only mentioned one fuse above, so make sure both are good.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 01-31-2012, 06:05 AM
Yup, just went through all this with my 84, although I have the autoheat. That relay in the rear fuse panel is a fickle one. Try swapping that out, after you confirmed the rear blower works by putting 12v to it. I found that my rear blower needed to be rebuilt before proceeding with the troubleshooting.
84 911 - 88 944 Turbo S - Sold
996 Turbo
996 Cab
Old 01-31-2012, 06:30 AM
djcdmv's Avatar
Subscribed... Mine only works intermittently.
Dave
Black 1985 911 Carrera M491
Old 01-31-2012, 06:31 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Heat.
While the heat is on, tap on the heater relay unit in the engine compartment.
If that creates the anomaly, open up the unit, and clean the relay contacts.
Let us know what you find.
Good luck,
Gerry
pm me as needed.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-31-2012, 06:37 AM
Ok boys, here's where I stand...as stated eariler, all the fuse in engine compartment are good. The blower back there was bench tested and fine. I cleaned the relay back there too. Even tried tapping it with a screwdriver. I also was able to bench test both the footwell blowers, they're good.
Now Mr. Bently said there are fuse for each blower in the footwells. I surely didn't see any there. Can anyone advise me on that one?
So where to now experts? I'll have my multi purpose electrical tester back this weekend.
Jamie
1985 911 Targa
Old 02-02-2012, 09:21 AM
1988 Carrera
shadowjack1's Avatar
I had the same problem. Turned out to be a bad ground between the blower and the engine.
The blower motor grounds to the back of the alt.
Old 02-02-2012, 09:33 AM
Fuses.
Jamie,
My Bentley does not show the footwell blower fuses until the 1988 M/Y.
Porsche added the fuses along with others in the late '86 production run.
Please check my post "Added fuses and relays".
pm me as needed.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-02-2012, 09:42 AM
That would be why I couldn't find them Gerry. lol I guess I read the wrong year. I'm going to try the ground suggestion from above. My motor was pulled right after I bought her and rebuilt. Maybe they didn't hook it back up. But I thought Mr. Bently said the ground was right next to the coil. Maybe that's for the rear fuses. I'll give a look.
Jamie
1985 911 Targa
Old 02-02-2012, 11:33 AM
On my '86 Carrera the blower motor in the engine compartment comes on when I pull up the levers between the seats. The footwell blowers only come on if the two levers are up and I turn the dial switch by the two levers.
You bench tested the blower motor in the engine compartment and you checked the switches (red levers) between the seats. So your problem is between these two points. Did you measure with a meter that after you pull the levers up there is 12V arriving at the blower motor? Did you measure that there is 12V at the two levers between the seats and after you pull the two levers up the current is going through?
Since all action starts with pulling the levers up you need to follow the current flow step by step to the blower motor.
Juergen
'86 Carrera Convertible
Old 02-02-2012, 12:58 PM
