Vibration when A/C is running
On my '88 cab, I am noticing a low frequency vibration when the A/C compressor is running. The A/C works fine.
Any one else experienced this? Any ideas what would cause it?
Ngueldner
Old 05-02-2002, 11:17 AM
Senior Member
Superman's Avatar
Go watche the belt while the A/C is running. Very possibly it is flapping. A/C systems commonly vibrate, in my experience. I suggest a move to a more mild climate where you can just remove A/C altogether.
Mocha 1978 911SC. "Coco"
Old 05-02-2002, 01:07 PM
stormcrow's Avatar
When the compressor has a load on it, it also puts a load on the engine. Mine does the same thing at idle and up to about 1500 rpm.
If the belt starts squeeling when it is tight, then the compressor has a high head pressure problem. Otherwise, it should be working ok.
Old 05-02-2002, 06:47 PM
