Cold Start Valve - Testing
I'm going test my fuel pressures this weekend.
However, I suspect that my cold start injector or regular injectors are leaking or not shutting off. Basically, when the car is warm (like stopping at a gas station), startup behaves like the car is flooded. I have recently replaced the check valve and accumulator.
my friend has suggested unplugging the cold start (temporarily). I'm thinking that this would have no effect if the injector is leaking - would it not still leak even if unplugged. Or, could the thermal sensor be causing it to stick on?
Thanks for any responses - this is mostly for my own education on the CIS and my plan is to follow the correct steps of testing pressures and then other items.
Vern
Old 04-23-2012, 12:30 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Your pal is owned.
The CSV uses starter voltage only, WHEN allowed by the thermo-time switch.
Old 04-23-2012, 07:14 PM
Scott R's Avatar
I doubt very much that the csv is leaking, or the injectors really. You need to get a test gauge on there and find out where the residual pressure is escaping. A lot of time it's this little o-ring in the fuel distributor.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-23-2012, 07:52 PM
