What is the best adhesive for door sill rubber strips
The door sill strip (plastic/rubber piece directly below the door) was coming loose. i removed it and cleaned everything and now I'm ready to re-glue. Can anybody tell me what the proper glue to use is. I live in a hot climate (over 100 in summer) and I need something that will hold and is not going to ooze out.
Thanks......Vern
Old 04-26-2012, 01:00 PM
Weekend Mechanic
vulcan300's Avatar
I used Wurth spray adhesive on mine. It tacks up almost immediately and creates an excellent bond. It's perfect for reinstalling the carpet too. It worked like a charm. Just make sure to mask the front while spraying then peel off the tape carefully after installation.
86 911 Carrera Targa
Old 04-26-2012, 02:10 PM
I used a 3M product for seals, seemed to work great.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 04-26-2012, 03:03 PM
schumicat's Avatar
3m trim adhesive
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 04-26-2012, 03:19 PM
docrodg's Avatar
Originally Posted by schumicat View Post
3m trim adhesive
+1 Used it for years on many cars both in the humid summers and cold winters in Upstate NY and the desert of CA. Always did well for me.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 04-26-2012, 06:18 PM
rsscotty's Avatar
The trick on using the 3M adhesive is to carefully read the instructions before you use it, not after you realize it isn't working very well.
Old 04-26-2012, 06:53 PM
Definitely 3M trim adhesive. Its available in black or beige. I use the color that blends best with the background just in case a little does ooze out, but that will not cause a problem. I have used it in the hot South for 15 years restoring VWs and never a problem. Follow instructions carefully!
Jim
79 911 SC
Old 04-26-2012, 07:30 PM
3M Weatherstrip Adhesive "Gorilla Snot". Same as the door seals.
Old 04-26-2012, 08:54 PM
Recreational User
porschenut's Avatar
I recommend DAP contact cement. It is amazingly strong, and bonds instantly on contact - no waiting, pressing, clamping, etc. Just press together and walk away.
Old 04-27-2012, 07:12 AM
kinein's Avatar
Send a message via Yahoo to kinein
+1 i live in the desert myself 100+ at times
1966 912 with 2.2 911 motor
1986 wide body 911
1995 993 Polar Silver
Old 04-27-2012, 08:56 AM
