redstrosekNic's Avatar
You might want to keep that battery as a story piece in your garage to remind yourself how ***** can happen.
Dustin
Old 04-28-2012, 07:36 AM
Plavan's Avatar
Originally Posted by rs6er View Post
vinegar will help neutralize the acid.
lol!
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 04-28-2012, 07:45 AM
AutoBahned
RWebb's Avatar
Optima. wants a special type of "Battery Tender" (float charger) - old thread on that, IIRC posts are by Optima Jim
you will need to very carefully clean out & flush out every tiny nook & cranny - & be SURE it did not get inside the unit body - if it did, you will likely need to drill some holes to get at it
every 1/2 year for the next few years you will want to check and be sure that the acid did not get in and weaken the front suspension -- you know, the stuff that holds the car up and the wheels on...
I see a repaint of that corner in your future.
at least it cannot reproduce and multiply like Ebola virus...
Old 04-28-2012, 10:48 AM
Ova Day
msterling's Avatar
Originally Posted by David View Post
The charger is a Battery Tender with wires permanently installed on the battery which is always on the car when it's in the garage.
I'm pretty sure the issue was with the acid/water level since I hadn't checked it in a while. I've also had issues with negative battery cable connection and should have replaced it long ago. There's plenty of blame on me so I'm admitting my fault to help prevent this from happening to somebody else.
My plan is to install a sealed battery like an Optima. Anybody see an issue with leaving a Battery Tender on them?
Wow! That really went up. Low electrolyte level from lengthy charging and an internal plate failing could cause a short when big current was drawn to run the starter motor. Having the charger on and connected may have added even more juice. If you weren't fiddling with the charger cables and the trunk was open then the fire probably started inside of the battery. I'm glad it didn't go up in your face. Hmm, a loose ground connector also could have sparked on startup.
Neutralize, rinse, repeat, repeat...........................
My 88 Carrera has very little current draw when parked. Just the clock is running. It can sit 4-8 weeks or more with no apparent loss of battery charge and the battery is at least 7 years old. I don't feel that I need a battery tender. You could also disconnect the ground cable or install a cutoff switch when storing.
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 04-28-2012, 12:03 PM
pete3799's Avatar
Never have had a charger on mine. Park it from Nov. to March. Leave it hooked up too.
I start it once in a while to move it around to work on it but that's it.
Pete
79 911SC RoW
Old 04-28-2012, 01:46 PM
1988 911 battery exploded
So I was driving my 911 down the highway after jump starting it from a drained battery. About a half hour into the drive a big BANG and spark seen in speedometer and tech clouds up. Pull over and realize battery completely exploded.
So replaced battery, car cranks but will not start. Anyone care to jump in here and let me know what could be the problem? Shop has had it for two days and claim they can not find why it will not start.
Old 08-01-2013, 02:03 PM
ROW '78 911 Targa
timmy2's Avatar
Fuses and relays all removed cleaned and tightened? Grounds too?
Massive spike in voltage to the CDI has fried it?
Old 08-01-2013, 02:37 PM
MConn's Avatar
See if you have power to the fuel pump, if not maybe the DME relay under the drivers seat is bad. The ECU under the drivers seat provides the signal to the coil. If you saw sparks in the speedometer, better check EVERYTHING.
Good luck. What is your location?
Mike
The more I learn, the less I know.
Old 08-02-2013, 06:35 AM
Taking it apart is easy
Jerome74911S's Avatar
Ya, Pete, but your garage is so big that it gets fully warmed up just driving from one corner to the other in there.
I don't leave mine over night without a tender on it - got to keep the clock accurate, you know.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 08-02-2013, 08:50 AM
88 Carrera, Guards Red
azhodge's Avatar
Bla Bla Bla
Old 01-11-2014, 10:22 PM
Banned
Originally Posted by azhodge View Post
Bla Bla Bla
You really have a way with words!
Old 01-11-2014, 11:47 PM
Originally Posted by djpateman View Post
Never start a car with a battery charger attached. Unless specifically designed for that use it will most likely damage the charger.
Is this true? I've started mine a few times with the charger still attached and no problems...
1966 Granite Green 911
Old 01-12-2014, 09:23 AM
Functionista
manbridge 74's Avatar
The issue with leaving the charger attached is likely due to battery outgassing in tight confines with little ventilation like when the hood remains shut etc. The sudden load on a not-so-good connection at charger leads could result in spark. Basically the charger makers are covering their behinds here. Use common sense and you'll be fine.
Also, the battery hold down importance shouldn't be underestimated. If battery is allowed to flop around the vibration could cause plates to loosen and internal shorting will result.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 01-12-2014, 11:28 AM
Cars and Cappuccino
tdw28210's Avatar
My '03 540 uses battery with a vent tube to help reduce gas build up. Not sure if can/should be adapted to the 911. $13 on the bay.
Battery Relief Breather Vent Tube Line Kit Set New for 82 10 BMW Models | eBay
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 01-12-2014, 12:20 PM
