can anyway i.d. this part??
i have this relyay, and have no idea where it goes. im restoring a 73911e targa. im sure i cmae from the trunk around the blower motor. when i put theblower motor back in, the motor doesnt work. i checked up in the trunk compartment, and just cant seem to find where it goes. any help would be great
There should be a part # on the relay, what is it?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
thats the problem, there is no part # on it. just seems funny, the blower doesnt work
Are there any numbers on the terminals? German relays use numbers like 15, 30, 87, 87a, 49
a/c relay in the smuggler's box usually.
theres no #'s on the relay. and not a/c , as the car isnt equipped with a/c. this is driving me crazy. i cant remember where it came from. i have a really good memory. i know i should have taken a pic of where i pulled it from.
Brando
Looks exactly like a voltage regulator
Turbo powa! 1977 911s. it's cool |
dumb question. what does the voltage regulator do???
Brando
Very simply keeps the voltage regulated to max 14volts or so. When they go bad the alternator can boil the battery.
The newer alternators had a VR on the back of the unit itself and most replace the alternator and VR as a unit but early cars, like yours, have it on the panel next to the cd. I like the older ones that are easy to replace, no need to remove the alternator. When I got a new alternator, I replaced the one with the VR on the back with the external VR for simplicity but most like the newer ones.
so then this came from the engine compartment?? i know i took it out of the trunk compartment
Brando
Well if you took it from the trunk, and it was plugged there, I could be wrong. I checked pelican for the A/C relay or related parts and couldn't find one that looked like it.
just seems funny. i got the car back from the paint shop. the blower worked before i took a lot of the parts out of the trunk compartment(so the trunk can be painted) i put the blower motor back in, plugged it in, and it wont work. not sure if this relay goes witht the blower motor, and why it doesnt work
76 911S Targa
Go to the engine compartment and look for a three blade female connector and see if it fits this part. It looks just like the voltage regulator next to my ignition box.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
benzboy,
Take another picture of the relay to show us the terminal numbers, and ... no camera flash |
