silver911rdb's Avatar
How to remove flag style mirrors without cutting wires?
Does anyone know how to do this? I"m pretty sure I have to disconnect the wiring from the mirror itself and leave the wiring in the door. I just can't see how the mirror comes apart to get to the connectors. It's a 1987 911. Thanks
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 04-30-2012, 02:36 PM
Fleabit peanut monkey
Bob Kontak's Avatar
If I am correct there is a maybe a 3 inch plastic ring that holds the mirror on. You can access the ring from the hole in the bottom of the flag part of the mirror. Use a flat blade screwdriver and loosen the ring. Once the ring is loose the mirror comes out and you can get into the innards pretty easily.
If it is the same as the 86 951 I worked on it's pretty easy.
Old 04-30-2012, 02:46 PM
There is a tool needed, which I did not have. You need this special tool to release the 6 wire connectors from the white round plastic connector. The connector is called a weatherpak connector. I will dig up the link, I just did this about a month ago. Resist the temptation to cut the wires.
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 04-30-2012, 03:36 PM
Here is the link:
I thought side mirror removal was easy
Note the mention about 10 posts from the top about a tool called Delphi Weatherpak - its a little 2-3 dollar item, and you cannot remove the mirror without either cutting wires, or getting your hands on this tool.
2016 Cayenne
Old 04-30-2012, 03:38 PM
Another related link:
Driver's Mirror Anyone else have this problem?
2016 Cayenne
Old 04-30-2012, 03:43 PM
I have done the mirror wire removal thing with a jewelers screwdriver to push on the tabs. Done it on both sides and it worked fine. Take a picture of which wires go where before doing this.
Kinsley
1980 SC Targa - MS2, EDIS
Old 04-30-2012, 04:13 PM
6 cylinder symphony
I used a straight pick to help convince the plug ends out of the plastic connector. I wish I'd drawn a schematic. Never could get them to work right after.
Irrelevant now. I cut the wires when I installed the aero mirrors. They are manual now.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 04-30-2012, 05:01 PM
Bob Kontak's Avatar
Jeebus Crispies - There is plenty of data out there for how to reconnect.
Old 04-30-2012, 05:34 PM
Thanks guys! That's just the info I needed. I just ordered the right tool to do the job. I managed to get the mirror off and found the 3 screws that hold the mirror housing together. Once disassembled I found the connector. They sure don't make it easy.
I'm in the process of stripping the car down for a proper repaint in Carmine Red. Hopefully it'll come out well.
Thanks again
-Rich-
1984 911 Track
Old 04-30-2012, 05:51 PM
I would have lent you my wire extraction tool. It makes pushing the connections out of the connector plug very easy and fast.
Old 04-30-2012, 05:55 PM
Thanks Rusnak! I figured for $5 bucks it would be a nice addition to my tool box.
-Rich-
1984 911 Track
Old 04-30-2012, 06:35 PM
Here's mine:
Old 04-30-2012, 07:48 PM
A dental tool, the kind hygenists use, is what I used and it worked great. Works wonders on plaque too.
"Charlie don't surf!"
Old 04-30-2012, 07:54 PM
