golfbuddah's Avatar
Alternator help
I replaced my alternator with a new valeo unit with internal regulator. Problem is the red alternator stays on when car is off and key is out????? Alternator seems to function perfectly except for that. 12.5 when on, 11.35 when cranking and 13.75 when engine starts and stays constant when reving. Alternator light goes off when engine starts. Book says diodes in alternator are gone when red light stays on. Ideas help.
Thanks Frank
Old 04-30-2012, 05:14 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by golfbuddah View Post
I replaced my alternator with a new valeo unit with internal regulator...
What did you had before and what car/years?
Who Will Live... Will See
Old 04-30-2012, 05:43 PM
golfbuddah's Avatar
had an externally regulated 1970.
Old 04-30-2012, 05:57 PM
pete3799's Avatar
Just replaced my externally regulated Marcal with a Pelican bought Valeo with internal regulator.
The black wire is not used on this model. Did you cut the black wire or in my case tape it up out of the way?
Pete
79 911SC RoW
Old 04-30-2012, 05:59 PM
golfbuddah's Avatar
Yes.. valeo had 3 connections. Blue wire for light. Brown for ground. Red to starte.
Old 04-30-2012, 06:04 PM
