Disable MSD ???
Can I safely disable the MSD ignition by unplugging the red wire to the starter so I can crank the engine (80 SC) for compression tests. Is this the only power supply?
If not any other suggestions?
Would rather not ruin the MSD box or anything else.
Old 05-07-2012, 01:57 PM
DW SD's Avatar
you should be able to safely disconnect the ground, instead.
Do you have a schematic?
Doug
1971 RSR - interpretation
Old 05-07-2012, 03:04 PM
I do have the schematic but am electrically challenged.
The red wire is uses a spade connector between MSD box and starter lug.
Is the ground wire safer?
Old 05-07-2012, 03:13 PM
I would rather be driving
jpnovak's Avatar
Just unplug the signal wire coming from the distributor. The MSD can not fire without signal.
Old 05-07-2012, 03:16 PM
Banned
Couldn't you just pull the coil wire out of the distributor cap? Seems the easiest.
Old 05-07-2012, 03:29 PM
Many options here. Pulling either red wire will disable it. Pulling the signal wire (purple and green pair) will disable it. Disconnecting the black ground wire (not black coil wire) will disable it. You could also take the center wire out of the distributor and have it sit somewhere close to a grounded part like an engine mount bolt. It will spark away harmlessly to the bolt. I would not just disconnect the high tension wire, that would be hard on the coil and MSD unit.
-Andy
Old 05-07-2012, 05:24 PM
wwest's Avatar
That would result in the spark jumping, and maybe leaving a carbon path, inside the coil. Most often jumps through the side of the coil cap (yes, actually) to one of the coil primary connections.
Old 05-07-2012, 06:10 PM
Banned
Really? I pulled both my center wires, individually, the other day. To check if both MSDs were firing.
Everything seems to be Ok.
Old 05-07-2012, 06:23 PM
It's not an instant distruction thing, it's just hard on the coil and CDI unit. You want the spark to go somewhere so it doesn't arc inside the coil.
-Andy
Old 05-08-2012, 12:22 PM
MSD disable
This is why I love this forum. So many people jumped in to help answer my question.
I have so many options for safely disabling my MSD box that I just might alternate between them for a little variety.
Thanks a lot guys. I appreciate the help.
Old 05-08-2012, 01:49 PM
Banned
-Andy
Humm, good to know. I didn't just let it hang, I held it an inch or so away from the fan housing and then the cap connector to see if the spark would jump. It did.
Beginners luck, I guess.
Old 05-08-2012, 01:56 PM
Banned
There really is very little, if anything, you can't find here.
Old 05-08-2012, 01:57 PM
Ground the WHITE wire, this also is a good way for theft deterient, a shidden switch that grounds the WHITE wire.
Old 05-08-2012, 04:15 PM
