What temp should a '72 911 E run at?
My '72 E runs at just over 210 normal driving, while my old 69 911T never got over 180. Is 210 too high for that car?
Russ
Old 05-06-2002, 05:13 PM
pwd72s's Avatar
Not really..210 is still well within the safe zone. Do you have the optional front cooler? I'm suspecting not, because I have to work hard to get above 180. In some ways more dangerous than 210. At 210, you're evaporating the moisture out...I wouldn't get worried until 230 or so...and at 240, I'd begin to really worry. That's getting hot... If the climate is hot where you are, you may want to start researching front mounted cooler options...but I'd say live through your first summer first, with an eye on the gauge?
Old 05-06-2002, 09:07 PM
H.G.P.'s Avatar
What would be the safe zone for the track? Thanks.
Old 05-06-2002, 09:16 PM
I agree - 210 seem right, around 205 would seem optimal.
I would think a car that never gets over 180 is much worse off than a car that runs at 210.
Old 05-06-2002, 09:25 PM
Administrator
Jack Olsen's Avatar
Track is the same as the street. 240 is where you should start worrying. 250 is where you should pull off and cool down.
(Edit: For an early car, I'd worry at 230, and pull off the track at 240.)
Old 05-06-2002, 11:28 PM
T Bird's Avatar
Russ
It all depends on the outside ambient temp. I never drive my car when it's under 50 degrees, but if it's between 50 and 70 with low humidity, my oil temp rarely exceeds 185 F. As it gets warmer outside or more humid, the oil temp will rise accordingly. On a nice hot summer day, the oil temp will level off at 210 F. I've never seen it hotter than that.
John
1972 911T Coupe
PCA- Potomac Region
Old 05-07-2002, 07:25 AM
racemor's Avatar
The extra oil cooler must really make a differrence. My car does not have one and at 80+ mph highway on an 80+ degree day it pushes 240. Makes me nervous when it does. But 15-20 degree cooler weather drops oil temp the exact same amount.
Tom
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 05-07-2002, 09:29 AM
I owned a 72"E" for about 7 years and through all of my ownership, this car never went above 200 even in extreme heat. I found that it spent most of it's life hovering between 180 and 210... never hitting the 210 mark. It never mattered how hard I drove it either! This particular car did have the front cooler.
Marc
Old 05-07-2002, 09:39 AM
Saffs's Avatar
Tom
Mine's much the same. 90F day at 90mph, for a long while, was 230F temp on the car ('73.5 T with no oil cooler).
'81 BMW Alpina C1 2.3
Just sold, '75 911S Targa
Old 05-07-2002, 09:47 AM
