Merv--
Congrats! Always nice to hear about a successful hop-up, especially a unique one.
As to getting "used" to it, I think I know what you mean. My car's acceleration doesn't *surprise* me like it used to. But it still scares the ***** out of me! Of course, I'm one of those poor souls who used a 3.3 motor as a base .
As to rear wheel horsepower and the conversion, I've done the job empirically on my particular set-up. Motorsport Design crank dyno'd my engine, put the engine in the car, then chassis dyno'd it. Same ambient temp, same gas, same boost. My drivetrain loss was just a shade below 14% at peak horsepower, and the curves below that looked very similar.
So, at 634 hp at the crank at 1 bar, I figure I'm damm close to 545 hp to the wheels. Subtract a bit off of that because I'm usually running pump gas on the street (and I NEVER dyno an engine, in OR out of a car, on pump gas), and I figure 500 is a safe bet.
And that will shred some rubber...as well as keep the driver interested indefinitely, I presume.
So, Merv...what's next for you besides an intercooler?
Old 05-07-2002, 12:48 PM
WydRyd's Avatar
LOL @ widebody911 & pbs911
Joeakso, my Carrera is the turbo optioned/look Carrera with all the 930 goodies (body, brakes & suspension (now KONI's)). It was a good base to do such a conversion on. I'm in Melbourne FYI...
930fan, thanks for the input. When I first set out on this project, my aim was to obtain between 350-400HP and I feel I have achieved my goal. When my mechanic asked me what I thought I should be getting, I immediately said 'bout 350-360". That's what my expectations were, so I am still over the moon with the end result.
G'Day Bruce. Your car must be a scarey fast ride I know you've used your 3.3 as a base, however, what mods have you done to it again? Opened up ports? Carrera intake? Motec? EVO GT2 CAMs? I'd love to hear specifics on the engine mods. 545hp is awesome! I already have an intercooler! My problem was I was getting no airflow over the intercooler and my intake temps was WAY too high (33-35degC). I typically see between 20-25degC under load on the road. That's a 10deg reduction in intake temps, so that has to count for a slight loss of HP on the dyno.
On the dyno, the Intercooler was basically a brick of aluminium with air passing through it. No cooling medium
Thinking of it now, the A/F ratio at high RPM would have been affected by the higher intake temps, so in a real world situation, the added cooling would have corrected the 12:1 A/F at the upper engine loads down to 11-11.5:1.
My next 'short-term' plan is to upgrade my ignition system and in the long-term 'migrate' to a Protomotive Stage 3 system, which is 545HP
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-07-2002, 04:47 PM
dickster's Avatar
WydRyd
congrats on an inspiring project.
i keep reading good stuff about promo. as well, so they must be doin something right.
the only things that concern me (apart from cost!) are my carrera brakes, and that 915. can the box handle loads more power (i know WydRyd has the g50)??
how much can the 915 safely handle??
i couldn't imagine shifting quick enough with mine to get 0 - 100 in 4.2 secs!!
i may have to make a trip to the usa soem time and smuggle the "kit" back to the uk.
Rich
'86 coupe
"there you are"
Old 05-08-2002, 06:03 AM
Glasgow 911SC's Avatar
Its only funny 'cause it's true!
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 05-08-2002, 06:57 AM
juan ruiz's Avatar
Well, Well, Well, So I go away come back and BOOM!400HP!!
Very nice Merv,any idea of the cost in USD ? Just out of curiosity
Old 05-10-2002, 11:29 AM
WydRyd's Avatar
Thanks Juan. I'd say approx $7-8k USD in total (or $14-16k AUD).
For me it was worth it because you can't get turbo cabrios down here
Merv
'89 911 Turbo Cab
Old 05-10-2002, 03:27 PM
