76s backdate - cis off and carbs on
Ok guys , i have a euro 76s 2.7ltr that being backdated to a 74 rs / rsr . i want to remove the cis and add webbers or pmo's . now who has done the swap before and what bits are needed beyond the carbs and process please .
"Funding my obsession one nut at a time" |
the search function is your friend...read and learn !
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Fleabit peanut monkey
Here are a few for starters........ Just search and you will find.
Backdate Question - RS Rear Fenders Update C4 RSR Project My 1977 911 S widebody backdate project 78 SC Backdate hybrid hotrod Ultimate Backdating Thread |
All good links with bits of info , i found the how to remove the cis thread but is there a how to install the carbs and what needs changing ( electrical , fuel lines , etc...) it must have been done 100 times so a how to must be there?
RETIRED
Well, low pressure fuel pump and regulator.....gaskets, proper manifolds, good carbs that have butterflies that don't leak. Most people block the fuel return line.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
carbs
Good Luck Bob.
1975 Targa W/ 2.2 1971 Sunroof coupe 2.2T Gone but not forgotten |
does the main metal fuel lines in the tunnel need changing or are they fine for dia?
"Funding my obsession one nut at a time" Last edited by advtracing; 01-23-2012 at 11:39 AM.. |
also coil and distrib. need changing ?
If you are going to use the CIS fuel pump you will need a pressure regulator, as suggested PMO makes a good one I have it on my 83SC with PMO carbs. Yes you can use the fuel line in the tunnel. You will need proper manifolds, linkage, air cleaners. You can use the coil as is but you really should have the distributor " set up " to run with carbs. Other than that really no additional electrical changes. You might find you'll go one heat range hotter on the spark plugs to prevent fouling it really depends on your tune. The motor will be a good runner but will run even better if/when you change pistons and cams to best utilize the carbs. Good luck.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Bird. It's the word...
John, my RS spec 2.7 started as a CIS engine.
I had the advantage of the engine going into an older car with the low pressure fuel pump (facet) and wiring. It's up to you if you run only one fuel line or two, but as mentioned you'll need a pressure regulator if using the CIS pump. The heads may have the CIS/MFI injector cut-outs, there's no need to worry about having them filled in. You probably should add some extra fuel filtration (carbies hate debris of any kind). I had the distributor recurved to suit and run hotter plugs. Consider getting the PMO heat isolators that go between the heads and the manifolds - they make a difference in summer (even in NZ )
John Forcier Current: 68L 2.0 Hotrod - build underway |
Lots of snow Porsche away
I am currently doing this conversion, why do you say not to worry about the CIS injector cut outs? I have the PMO heat insulators and original Porsche manifolds and I was under the impression filling the injector cut outs was critical to prevent the possiblity of a lean condition burning your valves?
yes just advised a similar thing , who can advise here ? i have std mainfold onto cis heads with the insulator to be installed and have been advised that the insulator will bend and cause issues if unsupported ?
I've responded to John on a PM, but my experience (so far) has been positive. I have CIS heads, insulation blocks and 36mm ports. Engine is 7 years old and I haven't struck the issue... I use Hylomar to assist the seal.
Well long time getting this done , and I need a couple of further questions answered please.
I have taken off the cis which was 35mm intake sized but the heads measure 37.5mm intake ? What am I missing here Secondly what is recommend to do with all the cis wires and plugs ? Do I just deloom back to the plug and remove all , is there any wires that need to stay or be convereted ? What should happen to the heat sender in the cam cover , do I remove and blank off ?
Did you notice the tunnel line fittings are not AN (which is what the PMO carbs, ITB's, and regulator uses) and require special adapters yet? There is a guy on here that I think makes the lines with proper fittings....
Gary R. |
i noticed that the fuel lines have connections , should be able to convert with the pipe fitting shop here
