AUS911SC3's Avatar
How do I measure the offset of my Fuchs rims
2 part question all:
1) How do i measure offset of my Fuchs rims
2) Why do some SCs with 8" & 9" Fuchs rims on the rear sit better under the guards than other SCs
Thanks heaps
Joe
Old 01-04-2010, 05:03 AM
T77911S's Avatar
look in the inside of the rim, you will see a number like ET 15, cant remember, that is 15 mm offset.
could be tire size???
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-04-2010, 05:21 AM
Bill Verburg's Avatar
ET = backspace - (.5 x overall rim width)
Bill Verburg
Old 01-04-2010, 05:22 AM
175K911's Avatar
If they're genuine Fuchs, they'll have the size and offset stamped in the back of the spokes. It'll look like this:
That's a 16x7 wheel with an et23.2 (23.3mm offset).
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 01-04-2010, 08:29 AM
Somatic Negative Optimist
Gunter's Avatar
AUS911SC,
Post the long numbers inside the Fuchs rims and we'll tell you what you have.
You'll find something like 911 ??? ??? ??
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-04-2010, 10:29 AM
m1franck's Avatar
This chart of part numbers may help
Not sure where I found this, but here's a handy chart for figuring out what Fuchs wheel offsets are:
Old 01-04-2010, 11:49 AM
Todd Simpson's Avatar
Ride height and alignment make a big difference. Negative camber (wheels leaning in at the top) is good for performance and also happens to look great.
These are 9's at a little over 3 degrees negative camber.
Old 01-04-2010, 06:20 PM
AUS911SC3's Avatar
Todd, that looks great, what offset are your 9"?
Old 01-04-2010, 07:28 PM
They are ET15.
Old 01-05-2010, 07:10 PM
Hi, I'm buying 7 and 8" 16" genuine Fuchs rims for my SC. Should I check the ET just to be sure they will fit with no spacers or such? ET23 (7") and ET10.6 (8") is the only possibility for my car?
Would you also check them for straightness on the balancing machine?
Thanks a lot!
Cheers
1982 911 SC Targa (USA)
Old 05-15-2012, 08:11 AM
Thanks a lot!
Cheers
yes to all of your ?'s
you want 7ET23.3 for the front, there are 2 16" Fuchs versions that will do, there is a 911 part # wheel and a 951 part # wheel that will work here. Both have the same basic stats 7x16ET23.3 but the 951 wheel has more room for brakes than the 911 wheel.
in back you want either the 911 part # 8x16ET10.6 wheel or the 911 part # 9x16ET15 wheel. But if you use a 951 part # ET23.3 8" wheel that will require spacers to bring the wheel more outboard.
w/ any used wheel always check for damage, the wheel could be bent or cracked or both
Bill Verburg
Old 05-15-2012, 08:29 AM
Thanks a lot Bill!
Old 05-16-2012, 07:38 AM
Shaun @ Tru6's Avatar
Todd, car looks great! What size tires do you have on it? Is it Gemini Blue?
Tru6 Restoration & Design
Old 05-16-2012, 08:22 AM
