tight brake pads
Hi folks,
Today I replaced the rear rotors and pads on my '88 Carrera. All very straightforward, apart from the fact that I had a devil of a time getting the second pad in -- had to tap it in with a hammer. Right now the rotor turns, but not freely.
My question is: will the system correct itself with use and break-in, or did I do something wrong. I know, probably a stupid question, but I tend to be a bit OCD with my automotive projects.
TIA!
Old 05-17-2012, 06:31 PM
tazzieman's Avatar
Normal , esp with new rotors as well. Drive and bed in (1/2 dozen good hard stops from speed ) and expect full efficacy after around 100-150km driving.
Often you have to compress the pistons back a little to get the new pads in.
How many miles on your calipers? Did you bleed the brakes too?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 05-17-2012, 06:40 PM
Senior Member
Jdub's Avatar
Bleed the caliper?
If you did not let off some pressure by bleeding or simply "venting" brake fluid then it will be resistant to pushing the caliper pucks in. Put in thicker (new) pads and now they are forced dead against the rotor (which is also new).
'78 Targa in Minerva Blue
Old 05-17-2012, 06:43 PM
Opening the system to retract the pistons not necessary. You can merely install a used pad, then use a wide pry bar betw rotor and pad to push the piston in as far as it goes.
Sherwood
Old 05-17-2012, 07:19 PM
River Rat
Dave 86 930 Fl's Avatar
Originally Posted by Hnichols View Post
Hi folks,
TIA!
You should buy a brake pad tool that will force the pistons back in to the caliper. Inexpensive and make the job much easier.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 05-18-2012, 01:59 AM
H-viken's Avatar
+1 Very nice to have.
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 05-18-2012, 02:05 AM
