NO LIFT's Avatar
Rear light problem
'88 Carrera
Lights off, brake pedal depressed:
-Right brake light normal
-left running light comes on as brake light
Lights on:
-two normal running lights
Lights on, brake pedal depressed
-Right light bright
-Left running light goes out, no brake light.
What gives?
2003 996 Carrera
gone but not forgotten '88Carrera '96 993 '89 951
Old 05-18-2012, 10:39 AM
Rescuer of old cars
Arne2's Avatar
Bad ground on the left light.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-18-2012, 11:04 AM
ROW '78 911 Targa
timmy2's Avatar
I'm sure you have replaced the bulb and tested the replacement in the normal working socket on the right.
1. Possible bad ground left side housing.
2. Socket is failing in the housing.
Numerous posts about the sockets failing at the back.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-18-2012, 11:10 AM
NO LIFT's Avatar
Thanks to both-
Bulb is good, I'm suspecting I have both issues listed by Timmy2, I've had loose sockets on the turn signals.
Guessing that the ground is behind the housing, I think I remember a couple bolts behind the lens. Anything I should be aware of (I have the terrible habit of breaking things that I haven't taken apart before)?
2003 996 Carrera
Old 05-18-2012, 11:16 AM
