Help re-assembling CIS
Hello Pelicaners,
I have an 83 911SC. I blew my old airbox so I went ahead and decided to take old one out and install a new one. While I was in there I changed a few other parts (cold star valve, hoses, etc). I am putting the thing back together and there are a couple parts giving me trouble.
The first one is a part the previous owner clearly installed himself. It has a volkswagen logo on it and when I looked up the number it said it was a Venturi Tube. I think I'm putting it back together as it was before but the needle-like long end is not clicking into the receiver end no matter how hard I push them together. Am I missing anything here? Here is the picture of how it stands now:
My second question is easier. I'm wondering where the end of the vacuum hose pictured below is connected to. It starts at the brass valve on the passenger side of the engine compartment.
Many thanks for any assistance you guys can provide.
Cheers
BN
Old 05-18-2012, 03:47 PM
Banned
Second pic - on the Turbos (CIS) that small vacuum hose on the decel valve connects to a port on the throttle body (vacuum created when throttle plate is closed).
Old 05-18-2012, 04:00 PM
Designer King
Paulporsche's Avatar
Vac Line Routing:
Don't know about the other thing. Sorry.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-18-2012, 04:31 PM
ROW '78 911 Targa
timmy2's Avatar
That is the vacuum line for the brakes. Not sure why PO would put a restrictor in there.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-18-2012, 08:39 PM
ROW '78 911 Targa
timmy2's Avatar
Items 33-36 are all I see that should be there....
Dennis
Old 05-18-2012, 09:07 PM
ROW '78 911 Targa
timmy2's Avatar
Hard to tell from picture, but looks like vacuum is split with this device? Where does it go? One to the brake MC booster. The other line goes where?
Dennis
Old 05-18-2012, 09:10 PM
Jim Williams's Avatar
The photo is of the vacuum multiplier. It is plumbed in above the throttle plate in the throttle body to below the throttle plate, with the angled portion supplying a vacuum to the brake booster. It is #21 in PaulPorsches post. In the diagram it is pointed off in the wrong direction from how it is installed on the engine. The tapered part inside coupled with a inside diameter reduction is what creates the vacuum though a venturi effect. The pieces shown in the photo should fit together with a little firm pressure.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 05-19-2012, 06:08 PM
Thank you Pelicaners
As always your help was invaluable. The vacuum multiplier would not budge so I fabricated a rubber sleeve out of tubing that keeps the two halves together. The engine is humming and running perfectly. I did the whole CIS job without dropping the engine. It's not easy but doable.
Thanks again to all of you. This website is a wonderful resource.
BN
Old 05-20-2012, 04:46 PM
