rnln's Avatar
how to re-install front sway bar?
After finish the front alignment, it's time to reinstall the front swaybar. I spent almost two nights under the car, then laying on the side of the fenders, still can't get the bolts in. At first, I jacked up the car. Then I drop it and drive it up on 2 pieces of 12 x 2 wood. Then I jack up the sway bar... still can't do it. Now my brackets, both messed up.
how do you guys do it? Do I have to finish everything and take the car to the mechanic shop to get it on the lift?
Fat butt 911, 1987
Old 03-14-2012, 12:12 AM
D911SC's Avatar
If I remember correctly from when I did it I raised the car so the wheels were off the ground. Then undo the top nut on one of the front struts and slide out of the camber plate. This will lower the A arm so that you can easily fit the sway bar. Simply slide the end into the bush on the side where the strut is still bolted in, loosely fit the brackets and then maneuver the other strut / A arm so the bar slides into the other bush.
Once this is done and the sway bar is positioned correctly (centered) you can slide the strut back into the camber plate, tighten up the nut making sure you torque correctly and replace the lock tab washer. You should then be able to tighten the sway bar brackets to their corrent torque.
This is of course assuming you have the solid bar and not the earlier drop link setup which wouldn't be standard on your car.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 03-14-2012, 12:53 AM
rnln's Avatar
The bushings on both ends are in place, but the bar is lower. I used floor jack to jack up the bar, but it is toward the rear several millimetters, and there is no way I can push it forward.
Fat butt 911, 1987
Old 03-14-2012, 08:50 AM
I reinstalled mine with one control arm disconnected. I slid the bar into the bushes on both control arms and then mounted the removed control arm. Then I bolted the bar to the body.
Old 03-14-2012, 10:24 AM
myamoto1's Avatar
Originally Posted by will hung View Post
i reinstalled mine with one control arm disconnected. I slid the bar into the bushes on both control arms and then mounted the removed control arm. Then i bolted the bar to the body.
+1
Josh
85 M491 Coupe - "Fat Bastard"
Old 03-14-2012, 11:26 AM
rnln's Avatar
the part I have problem is the last part you listed, bolt the bar to the body. it is hard to push it up the body. I used floor jack to jack it up, but when it's up the last mms, it's forced toward the rear of the car.
Fat butt 911, 1987
Old 03-14-2012, 12:14 PM
tazzieman's Avatar
Without a hoist it's a prick of a job - I used my 12 yo to insert the bolt whilst I held it all aligned (prying on the bracket to line up the holes)
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 03-14-2012, 01:06 PM
rnln's Avatar
Will get back under there again. I hate getting under the car.
Fat butt 911, 1987
Old 03-14-2012, 01:07 PM
Danny_Ocean's Avatar
I put my brackets on first, lubed up the bushings with silicone grease, then compressed the sway bar using a ratcheting web strap hooked to two hose clamps attached to the bar (looked like a compound hunting bow when I was done). Get the sway bar in place and release the ratchet. Caution: If the ratcheting web strap decides to release itself before the sway bar is in place, you will be donating the remainder of your Porsche restoration money to your dentist.
Old 03-14-2012, 02:17 PM
fred cook's Avatar
Front swa bar brackets......
I think that I remember using a long Phillips head screwdriver pushed thru one of the brackets to use as a lever to push it back into place to get the first bolt started. Then moved to the other side and did the same. Next step was to go back to the first bracket and start but not tighten the second bolt. Then, go to the second bracket and start the second bolt on that side. All done with the front end up on jack stands. Another method that should work would be to use a come a long to pull the swa bar back into position. Don't think I ever had to resort to that one (yet).
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 03-14-2012, 04:51 PM
rnln's Avatar
will try. It's ok, my teeth are not that nice anyway :lol:
Fat butt 911, 1987
Old 03-15-2012, 01:48 PM
rnln's Avatar
I did the screw driver thing. That's why the brackets are all screw up, bent
Fat butt 911, 1987
Old 03-15-2012, 01:49 PM
silicone paste the bar and the bushings, push one end through as far as you can, well past it's normal position, then slip the other end in with a few grunts and then center it. piece of cake.
206 637 4071
Old 03-15-2012, 03:12 PM
rnln's Avatar
I did it last night. Pushing it in my hand is not an option in my case. I am not a very weak guy but I think I need to increase my power 10 times to be able to do this. I banged it with a big mallet, will won't move. At last, I jacked it up with a floor jack, and used c-clamp to clamp it in little by little. The rear went in much easier.
Fat butt 911, 1987
Old 03-17-2012, 01:15 PM
it sounds like a similar deal i went through, "thought" i had silicon grease, in fact was not and made sliding the bar through the rubber almost impossible, rubber bush would push out. Went to Lowe's and got a tin of plumbers grease, cleaned all the other stuff off and could easily slide the bar several inches past normal to allow insertion in other side and alignment of the mount brackets. Felt really stupid afterwords as i had tried some stupid crazy things trying to get the bar in, with the right grease was an hour job (compared of a few hours of !!**%**). There is a thread on this. Good luck.
Old 03-17-2012, 01:52 PM
... and used claimb to claimb it in little by little.
Whatza "claimb"?
Old 03-17-2012, 09:20 PM
rnln's Avatar
wanted to say clamp, sorry. I corrected it.
Whatza "claimb"?
Fat butt 911, 1987
Old 03-18-2012, 01:17 AM
We now have the same post count. Weird, huh?
Old 03-18-2012, 11:00 AM
rnln's Avatar
Now, I got one more than you do
Fat butt 911, 1987
Old 03-18-2012, 10:33 PM
Hi, been struggling with the front sway bar deal. I replaced the bushings with the silicon grease, cannot realign the bolts. The car is a 84 carrera cab. Do you bolt up the bushing clamp not in the stone guard bolt holes first? My other question is did you guys jack up the stone guard or did you just replace the bar without the stone guard?
I am not working with a lift, just with the tires off, jk stands on the rear and front on the control arm end mounting bracket.
Old 05-12-2012, 10:20 AM
